이 버전에는 잘못된 편집 사항이 있을 수 있습니다. 최신 확인된 스냅샷으로 전환하십시오.
필요한 것
이 단계는 번역되지 않았습니다. 번역을 도와주십시오
Flip the laptop so the battery is facing upwards.
Push the battery release tabs toward the center of the device.
Remove the battery.
Using a plastic opening tool, pry the front silver bezel away from the colored plastic shell.
Unscrew the two screws using a Phillips #00 screwdriver from the metal casing that retains the screen.
Pull down the laptop's back, keeping the screen upright, held in place by two metal strips going along its sides.
Unscrew the 4 screws from the two strips.
Gently lay the screen down, being careful not to damage the ribbon connector.
Disconnect the cord connecting the screen to the rest of the laptop. The cable will be attached to the screen using tape, so it can be safely removed. The actual cord connection is at the circuit board.
다른 2명이 해당 안내서를 완성하였습니다.
