주요 콘텐츠로 건너뛰기
Dell Inspiron 910 Speaker Replacement
필요한 것
  1. Dell Inspiron 910 Speaker Replacement, Battery: 1 단계, 이미지 1/1
    • Flip the laptop so the battery is facing upwards.
    • Push the battery release tabs toward the center of the device.
    • Remove the battery.
  2. Dell Inspiron 910 Speaker Replacement, Keyboard: 2 단계, 이미지 1/1
    • Remove the two countersunk keyboard screws using the Phillips #00 screwdriver.
  3. Dell Inspiron 910 Speaker Replacement: 3 단계, 이미지 1/1
    • Lift up the keyboard using your fingers or a plastic opening tool.
    • Potential for device damage: Do not tear the ribbon cable hidden behind the keyboard.
    • Disconnect the cable by sliding the connector ears outward.
  4. Dell Inspiron 910 Speaker Replacement, Speaker: 4 단계, 이미지 1/1
    • After removing the keyboard, use the plastic opening tool or other form of leverage to remove the rest of the silver casing.
    • Depending on your model, there could still be some hidden screws on the bottom case of the laptop that hold the palm-rest in place.
  5. Dell Inspiron 910 Speaker Replacement: 5 단계, 이미지 1/1
    • Use a plastic tool to carefully pry the silver portion front of the top away from the colored portion.
  6. Dell Inspiron 910 Speaker Replacement: 6 단계, 이미지 1/1
    • Using the Phillips #00 screwdriver, remove the two small screws at the bottom corners of the speaker assembly.
    • Keep track of where you put the screws after you remove them. Keep screws of the same size together and away from screws of different sizes.
  7. Dell Inspiron 910 Speaker Replacement: 7 단계, 이미지 1/1
    • Slide out the cables connected to the speakers and the base below the keyboard.
    • Remove the speakers from the laptop.
결론
다른 3명이 해당 안내서를 완성하였습니다.
Kyle Beekman
회원 가입일: 04/05/12
144 평판
안내서 6개 작성하였습니다
Cal Poly, Team 14-10, Forte Spring 2012 Cal Poly, Team 14-10, Forte Spring 2012 회원
CPSU-FORTE-S12S14G10
5 회원들
안내서 7개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 2
7일 전: 2
30일 전: 4
전체 시간: 1,524
