주요 콘텐츠로 건너뛰기
Dell Inspiron 9100 Keyboard Replacement
필요한 것
  1. Dell Inspiron 9100 Keyboard Replacement, Battery: 1 단계, 이미지 1/3 Dell Inspiron 9100 Keyboard Replacement, Battery: 1 단계, 이미지 2/3 Dell Inspiron 9100 Keyboard Replacement, Battery: 1 단계, 이미지 3/3
    • Unplug the laptop from the power adapter and turn the power off.
    • Failure to unplug laptop before proceeding could result in risk of electric shock!
  2. Dell Inspiron 9100 Keyboard Replacement: 2 단계, 이미지 1/3 Dell Inspiron 9100 Keyboard Replacement: 2 단계, 이미지 2/3 Dell Inspiron 9100 Keyboard Replacement: 2 단계, 이미지 3/3
    • Slide the battery-lock tab and hold.
    • Flip the battery away from the chassis to remove it.
  3. Dell Inspiron 9100 Keyboard Replacement, Keyboard: 3 단계, 이미지 1/1
    • Turn the laptop around.
  4. Dell Inspiron 9100 Keyboard Replacement: 4 단계, 이미지 1/3 Dell Inspiron 9100 Keyboard Replacement: 4 단계, 이미지 2/3 Dell Inspiron 9100 Keyboard Replacement: 4 단계, 이미지 3/3
    • Use your fingers to gently pull up on the hinge covers. They will release with an audible snap.
    • Fold the screen back to 180 degrees.
    • Using your index fingers, pull up the hinge cover.
  5. Dell Inspiron 9100 Keyboard Replacement: 5 단계, 이미지 1/3 Dell Inspiron 9100 Keyboard Replacement: 5 단계, 이미지 2/3 Dell Inspiron 9100 Keyboard Replacement: 5 단계, 이미지 3/3
    • After the hinges pop, pull the hinge cover gently.
    • Pull the clear tab on the right side of the laptop up. This tab will disconnect the hinge cover from the laptop.
  6. Dell Inspiron 9100 Keyboard Replacement: 6 단계, 이미지 1/1
    • Remove the two 3mm screws on the top of the keyboard (nearest to the screen)
  7. Dell Inspiron 9100 Keyboard Replacement: 7 단계, 이미지 1/3 Dell Inspiron 9100 Keyboard Replacement: 7 단계, 이미지 2/3 Dell Inspiron 9100 Keyboard Replacement: 7 단계, 이미지 3/3
    • Tilt the keyboard away from the screen.
    • Pull up on the white tab underneath the keyboard to release the keyboard.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
Ana
회원 가입일: 01/11/11
111 평판
안내서 1개 작성함
Cal Poly, Team 13-2, Forte Winter 2011 Cal Poly, Team 13-2, Forte Winter 2011 회원
CPSU-FORTE-W11S13G2
5 회원들
안내서 8개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 1
30일 전: 9
전체 시간: 3,976
