주요 콘텐츠로 건너뛰기
Dell Inspiron 9100 Memory Replacement
필요한 것
  1. Dell Inspiron 9100 Memory Replacement, Battery: 1 단계, 이미지 1/3 Dell Inspiron 9100 Memory Replacement, Battery: 1 단계, 이미지 2/3 Dell Inspiron 9100 Memory Replacement, Battery: 1 단계, 이미지 3/3
    • Unplug the laptop from the power adapter and turn the power off.
    • Failure to unplug laptop before proceeding could result in risk of electric shock!
  2. Dell Inspiron 9100 Memory Replacement: 2 단계, 이미지 1/3 Dell Inspiron 9100 Memory Replacement: 2 단계, 이미지 2/3 Dell Inspiron 9100 Memory Replacement: 2 단계, 이미지 3/3
    • Slide the battery-lock tab and hold.
    • Flip the battery away from the chassis to remove it.
  3. Dell Inspiron 9100 Memory Replacement, Memory: 3 단계, 이미지 1/2 Dell Inspiron 9100 Memory Replacement, Memory: 3 단계, 이미지 2/2
    • Using the Philips #00 screwdriver, undo the screw on the memory module cover, labeled "M."
    • This screw will remain in the panel.
    • Pull the cover away from the laptop using your finger.
  4. Dell Inspiron 9100 Memory Replacement: 4 단계, 이미지 1/3 Dell Inspiron 9100 Memory Replacement: 4 단계, 이미지 2/3 Dell Inspiron 9100 Memory Replacement: 4 단계, 이미지 3/3
    • Use your fingertips to carefully spread apart the plastic white tabs.
    • Flip the RAM up at a 45 degree angle and remove it.
    • Hold the RAM by the edges only.
    • Ground yourself while dealing with RAM. Static shock can damage the memory. Store the RAM in an anti-static bag while it is not in use.
  5. Dell Inspiron 9100 Memory Replacement: 5 단계, 이미지 1/1
    • Repeat step four with the second RAM.
결론
charlierefvem
회원 가입일: 01/11/11
854 평판
안내서 7개 작성하였습니다
Cal Poly, Team 13-2, Forte Winter 2011 Cal Poly, Team 13-2, Forte Winter 2011 회원
CPSU-FORTE-W11S13G2
5 회원들
안내서 8개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 1
30일 전: 15
전체 시간: 3,506
