이 안내서에는 최근 변경 사항이 더 있습니다. 최신 비검증 버전으로 전환하십시오.
소개
This guide will help you replace the RAM (memory module) on your Dell Inspiron 9100. It is useful to replace the RAM if your computer runs slower than normal or if your programs constantly freeze.
This guide requires a Phillips #00 screwdriver.
필요한 것
Using the Philips #00 screwdriver, undo the screw on the memory module cover, labeled "M."
Pull the cover away from the laptop using your finger.
거의 끝나갑니다!
결론
