주요 콘텐츠로 건너뛰기
Dell Inspiron 9300 Modem Replacement
필요한 것
  1. Dell Inspiron 9300 Modem Replacement, Modem & WIFI Card Prerequisite: 1 단계, 이미지 1/3 Dell Inspiron 9300 Modem Replacement, Modem & WIFI Card Prerequisite: 1 단계, 이미지 2/3 Dell Inspiron 9300 Modem Replacement, Modem & WIFI Card Prerequisite: 1 단계, 이미지 3/3
    이 단계에 사용된 도구:
    Anti-Static Wrist Strap
    $7.95
    구매
    • Flip the computer over and place it on a clean level surface.
    • Loosen the screws using a size #0 Phillips screwdriver.
    • The screws do not come completely out.
    • It is strongly recommended that the Anti-Static Wrist Strap is used to avoid damage to internal components.
  2. Dell Inspiron 9300 Modem Replacement: 2 단계, 이미지 1/2 Dell Inspiron 9300 Modem Replacement: 2 단계, 이미지 2/2
    • Once the screws are loose, open the panel using a plastic opening tool to access the components below.
    • The modem card should be labeled MODEM. The WIFI card is larger than the modem and closer to the outer edge of the computer.
  3. Dell Inspiron 9300 Modem Replacement, Modem Card: 3 단계, 이미지 1/2 Dell Inspiron 9300 Modem Replacement, Modem Card: 3 단계, 이미지 2/2
    • Remove the screw holding the card in place using a size #0 Phillips screwdriver.
    • Gently unplug the card from the connecting black wire using a black spudger.
    • The modem can now be safely removed.
결론
Randy McMillan
회원 가입일: 09/21/16
738 평판
안내서 4개 작성하였습니다
Master Techs Master Techs 회원
Community
321 회원들
안내서 1,516개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 1
30일 전: 14
전체 시간: 200
