주요 콘텐츠로 건너뛰기
Dell Inspiron B130 Fan Replacement
필요한 것
  1. Dell Inspiron B130 Fan Replacement, Battery: 1 단계, 이미지 1/3 Dell Inspiron B130 Fan Replacement, Battery: 1 단계, 이미지 2/3 Dell Inspiron B130 Fan Replacement, Battery: 1 단계, 이미지 3/3
    • First, make sure your computer is turned off.
    • Remove the battery by flipping the two switches under the battery and pulling it out
  2. Dell Inspiron B130 Fan Replacement: 2 단계, 이미지 1/3 Dell Inspiron B130 Fan Replacement: 2 단계, 이미지 2/3 Dell Inspiron B130 Fan Replacement: 2 단계, 이미지 3/3
    • Push the tab from the battery, downwards to unlock the battery.
    • The tab should be in the position next to the unlocked indicator.
  3. Dell Inspiron B130 Fan Replacement: 3 단계, 이미지 1/3 Dell Inspiron B130 Fan Replacement: 3 단계, 이미지 2/3 Dell Inspiron B130 Fan Replacement: 3 단계, 이미지 3/3
    • Now, push the other tab (the one right under the battery) from right to left.
    • Now the battery will be loose; lift the battery up and out of the computer.
  4. Dell Inspiron B130 Fan Replacement, Disk Drive: 4 단계, 이미지 1/3 Dell Inspiron B130 Fan Replacement, Disk Drive: 4 단계, 이미지 2/3 Dell Inspiron B130 Fan Replacement, Disk Drive: 4 단계, 이미지 3/3
    • Remove the 8mm screw
    • Use the plastic opening tool to push out the disk drive.
    • Pull the disk drive out with the opposite hand.
  5. Dell Inspiron B130 Fan Replacement: 5 단계, 이미지 1/1
    • You can now remove the disk drive.
  6. Dell Inspiron B130 Fan Replacement, Hard Drive: 6 단계, 이미지 1/3 Dell Inspiron B130 Fan Replacement, Hard Drive: 6 단계, 이미지 2/3 Dell Inspiron B130 Fan Replacement, Hard Drive: 6 단계, 이미지 3/3
    • This particular computer is missing its hard drive.
    • Remove the two screws.
    • Remove the plastic cover by lifting from the groove as indicated.
    • Remove the hard drive from the computer by lifting up and out.
  7. Dell Inspiron B130 Fan Replacement, Keyboard: 7 단계, 이미지 1/1
    • Put down the computer and open up the screen.
    • There is a long piece of plastic underneath the screen that you will have to remove.
  8. Dell Inspiron B130 Fan Replacement: 8 단계, 이미지 1/3 Dell Inspiron B130 Fan Replacement: 8 단계, 이미지 2/3 Dell Inspiron B130 Fan Replacement: 8 단계, 이미지 3/3
    • When you pry the plastic plate off, be careful and pry gently so you do not crack the plastic.
    • Insert the plastic opening tool into the little slot.
    • Lift up gently and remove the plastic cover.
  9. Dell Inspiron B130 Fan Replacement: 9 단계, 이미지 1/1
    • Remove the two 4mm screws at the top of the keyboard.
    • The keyboard is now loose but don't pull it out just yet. It is still connected underneath. Be gentle when lifting keyboard so you do not damage this connection.
  10. Dell Inspiron B130 Fan Replacement: 10 단계, 이미지 1/2 Dell Inspiron B130 Fan Replacement: 10 단계, 이미지 2/2
    • Lift keyboard up slightly and you will see the keyboard connection.
    • This black tab has to be lifted up to remove the keyboard.
    • Put your finger underneath the tab and pull back gently as indicated.
    • You can now remove the keyboard.
  11. Dell Inspiron B130 Fan Replacement, Screen: 11 단계, 이미지 1/3 Dell Inspiron B130 Fan Replacement, Screen: 11 단계, 이미지 2/3 Dell Inspiron B130 Fan Replacement, Screen: 11 단계, 이미지 3/3
    • This reveals two connections that must be removed.
    • Remove the one with the blue tape by lifting up on the tape gently.
  12. Dell Inspiron B130 Fan Replacement: 12 단계, 이미지 1/2 Dell Inspiron B130 Fan Replacement: 12 단계, 이미지 2/2
    • Remove the other connection by pulling apart gently.
  13. Dell Inspiron B130 Fan Replacement: 13 단계, 이미지 1/1
    • Remove the two 6mm screws that are directly under the screen.
  14. Dell Inspiron B130 Fan Replacement: 14 단계, 이미지 1/2 Dell Inspiron B130 Fan Replacement: 14 단계, 이미지 2/2
    • Close the computer and flip it over so that the back is facing up.
    • Remove the two 6mm screws that are behind each of the screens pivot points.
    • Open up the screen and now it can be lifted up and off of the computer.
  15. Dell Inspiron B130 Fan Replacement, CPU: 15 단계, 이미지 1/2 Dell Inspiron B130 Fan Replacement, CPU: 15 단계, 이미지 2/2
    • Remove the 6 mm screw.
    • Lift the plastic cover off.
  16. Dell Inspiron B130 Fan Replacement: 16 단계, 이미지 1/2 Dell Inspiron B130 Fan Replacement: 16 단계, 이미지 2/2
    • Loosen the 4 screws.
    • These screws stay connected to the heat sink.
    • Remove the heat sink from the computer.
  17. Dell Inspiron B130 Fan Replacement: 17 단계, 이미지 1/1
    • Use a flat head screwdriver to turn the screw one quarter turn into the unlock position.
    • Remove the CPU.
  18. Dell Inspiron B130 Fan Replacement, RAM and Wireless: 18 단계, 이미지 1/2 Dell Inspiron B130 Fan Replacement, RAM and Wireless: 18 단계, 이미지 2/2
    • Remove the three 6mm screws.
    • Lift the plastic cover off to reveal the RAM and the Wireless.
  19. Dell Inspiron B130 Fan Replacement: 19 단계, 이미지 1/3 Dell Inspiron B130 Fan Replacement: 19 단계, 이미지 2/3 Dell Inspiron B130 Fan Replacement: 19 단계, 이미지 3/3
    • To remove the RAM, push outward against the metal brackets.
    • The first RAM will pop up so you can just pull it right out.
    • Repeat the first step again to remove the second RAM chip.
    • Installation is the reverse of removal.
  20. Dell Inspiron B130 Fan Replacement: 20 단계, 이미지 1/2 Dell Inspiron B130 Fan Replacement: 20 단계, 이미지 2/2
    • To remove the wireless chip, push outward on its two metal brackets.
    • Do not remove the chip just yet, the wire that connects this chip must first be removed.
  21. Dell Inspiron B130 Fan Replacement: 21 단계, 이미지 1/2 Dell Inspiron B130 Fan Replacement: 21 단계, 이미지 2/2
    • To remove the wire, hold the wireless chip firmly and pull the connection straight up off of the chip.
  22. Dell Inspiron B130 Fan Replacement, Motherboard: 22 단계, 이미지 1/2 Dell Inspiron B130 Fan Replacement, Motherboard: 22 단계, 이미지 2/2
    • Remove the twelve 8mm screws.
    • The picture shows everything still installed in the computer. At this point, the CPU, RAM, battery, hard drive and wireless chip should all be removed.
  23. Dell Inspiron B130 Fan Replacement: 23 단계, 이미지 1/2 Dell Inspiron B130 Fan Replacement: 23 단계, 이미지 2/2
    • Turn the computer over and remove the two 4 mm screws that are located just below where the screen should be.
    • Remove the five 6mm screws that remain.
  24. Dell Inspiron B130 Fan Replacement: 24 단계, 이미지 1/2 Dell Inspiron B130 Fan Replacement: 24 단계, 이미지 2/2
    이 단계에 사용된 도구:
    구매
    • Disconnect these two connections.
    • Do not pull by the wires! This can damage the connection. Use tweezers to grab by the white plastic piece and push outward.
  25. Dell Inspiron B130 Fan Replacement: 25 단계, 이미지 1/3 Dell Inspiron B130 Fan Replacement: 25 단계, 이미지 2/3 Dell Inspiron B130 Fan Replacement: 25 단계, 이미지 3/3
    • This connection must also be removed.
    • Use tweezers to grab the small black connector and pull it straight back.
    • You can now disconnect this wire.
  26. Dell Inspiron B130 Fan Replacement: 26 단계, 이미지 1/3 Dell Inspiron B130 Fan Replacement: 26 단계, 이미지 2/3 Dell Inspiron B130 Fan Replacement: 26 단계, 이미지 3/3
    • The whole cover/frame can be pulled off of the top of the motherboard.
    • The motherboard can now be removed by pulling up and sliding out to the right.
  27. Dell Inspiron B130 Fan Replacement, Fan: 27 단계, 이미지 1/3 Dell Inspiron B130 Fan Replacement, Fan: 27 단계, 이미지 2/3 Dell Inspiron B130 Fan Replacement, Fan: 27 단계, 이미지 3/3
    • Remove these four 4 mm screws.
    • Turn the motherboard over and lift the fan up.
    • Disconnect the wire that connects the fan to the motherboard by pulling up gently.
    • You can now remove the fan.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
Patrick McNeil
회원 가입일: 10/19/16
937 평판
안내서 8개 작성하였습니다
UMass Dartmouth, Team 1-8, Catania Fall 2016 UMass Dartmouth, Team 1-8, Catania Fall 2016 회원
UMASSD-CATANIA-F16S1G8
3 회원들
안내서 9개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 1
30일 전: 15
전체 시간: 352
