주요 콘텐츠로 건너뛰기
Dell Inspiron B130 RAM and Wireless Replacement
필요한 것
  1. Dell Inspiron B130 RAM and Wireless Replacement, Battery: 1 단계, 이미지 1/3 Dell Inspiron B130 RAM and Wireless Replacement, Battery: 1 단계, 이미지 2/3 Dell Inspiron B130 RAM and Wireless Replacement, Battery: 1 단계, 이미지 3/3
    • First, make sure your computer is turned off.
    • Remove the battery by flipping the two switches under the battery and pulling it out
  2. Dell Inspiron B130 RAM and Wireless Replacement: 2 단계, 이미지 1/3 Dell Inspiron B130 RAM and Wireless Replacement: 2 단계, 이미지 2/3 Dell Inspiron B130 RAM and Wireless Replacement: 2 단계, 이미지 3/3
    • Push the tab from the battery, downwards to unlock the battery.
    • The tab should be in the position next to the unlocked indicator.
  3. Dell Inspiron B130 RAM and Wireless Replacement: 3 단계, 이미지 1/3 Dell Inspiron B130 RAM and Wireless Replacement: 3 단계, 이미지 2/3 Dell Inspiron B130 RAM and Wireless Replacement: 3 단계, 이미지 3/3
    • Now, push the other tab (the one right under the battery) from right to left.
    • Now the battery will be loose; lift the battery up and out of the computer.
  4. Dell Inspiron B130 RAM and Wireless Replacement, RAM and Wireless: 4 단계, 이미지 1/2 Dell Inspiron B130 RAM and Wireless Replacement, RAM and Wireless: 4 단계, 이미지 2/2
    • Remove the three 6mm screws.
    • Lift the plastic cover off to reveal the RAM and the Wireless.
  5. Dell Inspiron B130 RAM and Wireless Replacement: 5 단계, 이미지 1/3 Dell Inspiron B130 RAM and Wireless Replacement: 5 단계, 이미지 2/3 Dell Inspiron B130 RAM and Wireless Replacement: 5 단계, 이미지 3/3
    • To remove the RAM, push outward against the metal brackets.
    • The first RAM will pop up so you can just pull it right out.
    • Repeat the first step again to remove the second RAM chip.
    • Installation is the reverse of removal.
  6. Dell Inspiron B130 RAM and Wireless Replacement: 6 단계, 이미지 1/2 Dell Inspiron B130 RAM and Wireless Replacement: 6 단계, 이미지 2/2
    • To remove the wireless chip, push outward on its two metal brackets.
    • Do not remove the chip just yet, the wire that connects this chip must first be removed.
  7. Dell Inspiron B130 RAM and Wireless Replacement: 7 단계, 이미지 1/2 Dell Inspiron B130 RAM and Wireless Replacement: 7 단계, 이미지 2/2
    • To remove the wire, hold the wireless chip firmly and pull the connection straight up off of the chip.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
Patrick McNeil
회원 가입일: 10/19/16
937 평판
안내서 8개 작성하였습니다
UMass Dartmouth, Team 1-8, Catania Fall 2016 UMass Dartmouth, Team 1-8, Catania Fall 2016 회원
UMASSD-CATANIA-F16S1G8
3 회원들
안내서 9개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 3
30일 전: 4
전체 시간: 258
