소개
This guide will tell you how to replace the screen. The screen has issues very seldom as the only real way it ends up not displaying correctly is if the screen itself gets damaged or there is a connection issue within the laptop.
필요한 것
Remove the battery by flipping the two switches under the battery and pulling it out
Put down the computer and open up the screen.
There is a long piece of plastic underneath the screen that you will have to remove.
This reveals two connections that must be removed.
Remove the one with the blue tape by lifting up on the tape gently.
