주요 콘텐츠로 건너뛰기
Dell Inspiron Duo Battery Replacement
필요한 것
  1. Dell Inspiron Duo Battery Replacement, Front Cover: 1 단계, 이미지 1/2 Dell Inspiron Duo Battery Replacement, Front Cover: 1 단계, 이미지 2/2
    • Working on your device while it is turned on may result in electric shock. Make sure to shut down and unplug your device before you begin.
    • Flip your device over so the bottom panel is facing up.
    • To remove the old battery from the laptop, first unscrew the eight screws (size M2.5x8) from the bottom with a Phillips #0 screwdriver, this will allow the removal of the keyboard and front panel.
  2. Dell Inspiron Duo Battery Replacement: 2 단계, 이미지 1/2 Dell Inspiron Duo Battery Replacement: 2 단계, 이미지 2/2
    • Flip the device over again and open the laptop so that you have access to the keyboard. There are hooks on the bottom of the keyboard, but gently pulling the keyboard towards the monitor will allow it to pull out easily. Be sure to unclamp the ribbon cable. Remove the three screws under the keyboard.
    • Remove the three plastic Keyboard and trackpad connectors (these are labeled with a blue circle on the second photograph).
  3. Dell Inspiron Duo Battery Replacement: 3 단계, 이미지 1/2 Dell Inspiron Duo Battery Replacement: 3 단계, 이미지 2/2
    • Next, remove the top cover from the device using the plastic opening tools. It snaps in on the sides, so don't worry if you hear it unsnapping; it's not breaking.
  4. Dell Inspiron Duo Battery Replacement, Battery: 4 단계, 이미지 1/2 Dell Inspiron Duo Battery Replacement, Battery: 4 단계, 이미지 2/2
    • Remove the cover, and locate the battery. The battery can be found in the lower portion of the device. It will have a blue Li-ion Recycling symbol on the right half, and "Dell Inc. Dell Battery Module" on the left side.
    • Remove the two screws from the bottom center of the battery, the two screws from the top outside corners, and the single screw in the top-center.
  5. Dell Inspiron Duo Battery Replacement: 5 단계, 이미지 1/2 Dell Inspiron Duo Battery Replacement: 5 단계, 이미지 2/2
    • Lastly, remove the white power connector that attaches the battery to the motherboard ( to make this easier to see, the power connector is outlined in red in the photograph). Now remove the battery from the device and place to the side.
결론
다른 8명이 해당 안내서를 완성하였습니다.
Steven Luther
회원 가입일: 06/23/15
778 평판
안내서 3개 작성하였습니다
UW Tacoma, Team 1-1, Liner SU 2015 UW Tacoma, Team 1-1, Liner SU 2015 회원
UWT-LINER-SU15S1G1
3 회원들
안내서 4개 작성하였습니다
댓글 한 개
i want the battery my email is engkaim95@gmail,com
KAIMUKILWA J TIBAZARWA - 답글
댓글 쓰기
조회 통계:
24 시간 전: 2
7일 전: 5
30일 전: 51
전체 시간: 9,134
