주요 콘텐츠로 건너뛰기
Dell Inspiron E1405 Hard Drive Replacement
필요한 것
  1. Dell Inspiron E1405 Hard Drive Replacement, Battery: 1 단계, 이미지 1/1
    • Save your work, power the laptop off, and ensure that the charging cable is unplugged before removing the battery.
    • Flip the laptop over.
    • Locate the battery release switch on the bottom of the laptop.
  2. Dell Inspiron E1405 Hard Drive Replacement: 2 단계, 이미지 1/3 Dell Inspiron E1405 Hard Drive Replacement: 2 단계, 이미지 2/3 Dell Inspiron E1405 Hard Drive Replacement: 2 단계, 이미지 3/3
    • Slide the battery release switch away from the lock symbol until you hear the battery click.
    • Slide the battery towards the back of the laptop until it comes free.
  3. Dell Inspiron E1405 Hard Drive Replacement, Hard Drive: 3 단계, 이미지 1/2 Dell Inspiron E1405 Hard Drive Replacement, Hard Drive: 3 단계, 이미지 2/2
    • Locate the hard drive access door.
    • Remove the two 5.5mm screws with a #00 Phillips screwdriver. These screws are securing the hard drive access door.
  4. Dell Inspiron E1405 Hard Drive Replacement: 4 단계, 이미지 1/2 Dell Inspiron E1405 Hard Drive Replacement: 4 단계, 이미지 2/2
    • Using your fingers, open and remove the access door from the laptop, exposing the hard drive underneath.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
Sarah Neal Secrest
회원 가입일: 03/20/17
597 평판
안내서 5개 작성하였습니다
Texas Tech, Team S8-G3, Bennett Spring 2017 Texas Tech, Team S8-G3, Bennett Spring 2017 회원
TTU-BENNETT-S17S8G3
3 회원들
안내서 5개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 2
30일 전: 17
전체 시간: 1,182
