주요 콘텐츠로 건너뛰기
Dell Inspiron E1405 Heat Sink Replacement
필요한 것
  1. Dell Inspiron E1405 Heat Sink Replacement, Battery: 1 단계, 이미지 1/1
    • Save your work, power the laptop off, and ensure that the charging cable is unplugged before removing the battery.
    • Flip the laptop over.
    • Locate the battery release switch on the bottom of the laptop.
  2. Dell Inspiron E1405 Heat Sink Replacement: 2 단계, 이미지 1/3 Dell Inspiron E1405 Heat Sink Replacement: 2 단계, 이미지 2/3 Dell Inspiron E1405 Heat Sink Replacement: 2 단계, 이미지 3/3
    • Slide the battery release switch away from the lock symbol until you hear the battery click.
    • Slide the battery towards the back of the laptop until it comes free.
  3. Dell Inspiron E1405 Heat Sink Replacement, Heat Sink: 3 단계, 이미지 1/3 Dell Inspiron E1405 Heat Sink Replacement, Heat Sink: 3 단계, 이미지 2/3 Dell Inspiron E1405 Heat Sink Replacement, Heat Sink: 3 단계, 이미지 3/3
    • Remove/loosen the eight 4.8mm screws with a #1 Phillips screwdriver securing the bottom panel.
    • Remove the bottom panel.
  4. Dell Inspiron E1405 Heat Sink Replacement: 4 단계, 이미지 1/3 Dell Inspiron E1405 Heat Sink Replacement: 4 단계, 이미지 2/3 Dell Inspiron E1405 Heat Sink Replacement: 4 단계, 이미지 3/3
    • Loosen the five 5.5mm screws with a #1 Phillips screwdriver securing the heat sink and clean it with compressed air
    • Gently lift the heat sink from the side, as indicated in the picture.
결론
Sarah Neal Secrest
회원 가입일: 03/20/17
597 평판
안내서 5개 작성하였습니다
Texas Tech, Team S8-G3, Bennett Spring 2017 Texas Tech, Team S8-G3, Bennett Spring 2017 회원
TTU-BENNETT-S17S8G3
3 회원들
안내서 5개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 12
전체 시간: 232
