주요 콘텐츠로 건너뛰기
Dell Inspiron E1405 LCD Screen Replacement
필요한 것
  1. Dell Inspiron E1405 LCD Screen Replacement, Battery: 1 단계, 이미지 1/1
    • Save your work, power the laptop off, and ensure that the charging cable is unplugged before removing the battery.
    • Flip the laptop over.
    • Locate the battery release switch on the bottom of the laptop.
  2. Dell Inspiron E1405 LCD Screen Replacement: 2 단계, 이미지 1/3 Dell Inspiron E1405 LCD Screen Replacement: 2 단계, 이미지 2/3 Dell Inspiron E1405 LCD Screen Replacement: 2 단계, 이미지 3/3
    • Slide the battery release switch away from the lock symbol until you hear the battery click.
    • Slide the battery towards the back of the laptop until it comes free.
  3. Dell Inspiron E1405 LCD Screen Replacement, LCD Screen: 3 단계, 이미지 1/3 Dell Inspiron E1405 LCD Screen Replacement, LCD Screen: 3 단계, 이미지 2/3 Dell Inspiron E1405 LCD Screen Replacement, LCD Screen: 3 단계, 이미지 3/3
    • Use your fingers or a spudger to remove the six small rubber covers off the display assembly.
    • Remove the six 5.7 mm screws with a Phillips #00 screwdriver.
  4. Dell Inspiron E1405 LCD Screen Replacement: 4 단계, 이미지 1/1
    • Use your fingers to gently pry the front bezel off the display assembly. Start at a corner and work your way around.
    • Remove the front display bezel when it comes free.
  5. Dell Inspiron E1405 LCD Screen Replacement: 5 단계, 이미지 1/3 Dell Inspiron E1405 LCD Screen Replacement: 5 단계, 이미지 2/3 Dell Inspiron E1405 LCD Screen Replacement: 5 단계, 이미지 3/3
    • Remove the three 3.6 mm screws using a Phillips #00 screwdriver on both sides of the display.
    • Remove the LCD screen from the display assembly.
  6. Dell Inspiron E1405 LCD Screen Replacement: 6 단계, 이미지 1/2 Dell Inspiron E1405 LCD Screen Replacement: 6 단계, 이미지 2/2
    • Unplug the VGA cable by pushing the two metal sides towards the middle of the strip.
    • Gently pull the VGA cable away to release the strip.
  7. Dell Inspiron E1405 LCD Screen Replacement: 7 단계, 이미지 1/2 Dell Inspiron E1405 LCD Screen Replacement: 7 단계, 이미지 2/2
    • Remove the next connection by pressing the two metal sides towards the middle. Then gently pull up the ribbon.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
Sarah Neal Secrest
회원 가입일: 03/20/17
597 평판
안내서 5개 작성하였습니다
Texas Tech, Team S8-G3, Bennett Spring 2017 Texas Tech, Team S8-G3, Bennett Spring 2017 회원
TTU-BENNETT-S17S8G3
3 회원들
안내서 5개 작성하였습니다
댓글 한 개
I need complete body *Dell INSPIRON E1405 .
St Master Fun - 답글
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 1
30일 전: 11
전체 시간: 447
