주요 콘텐츠로 건너뛰기
Dell Inspiron E1505 Battery Replacement
  1. Dell Inspiron E1505 Battery Replacement, Battery: 1 단계, 이미지 1개 중 1개
    • Before any work can be done ensure that the laptop is powered off.
    • Use either the power button on the computer or issue a shutdown from the operating system.
    • Once the device is off place the laptop on a flat surface and flip it so that the bottom is facing upwards.
  2. Dell Inspiron E1505 Battery Replacement: 2 단계, 이미지 1개 중 1개
    • Locate the battery release switch on the bottom of the laptop.
    • Once located slide the switch into the unlock position.
  3. Dell Inspiron E1505 Battery Replacement: 3 단계, 이미지 1개 중 1개
    • Locate the “lip” on the laptop to lift the battery outside of the compartment.
    • Once the battery is out, you will be able to find the replacement part number in order to purchase a new battery.
  4. Dell Inspiron E1505 Battery Replacement: 4 단계, 이미지 1개 중 1개
    • Once the new battery has been acquired take the battery and place it in the empty battery slot.
    • Slide the switch into the lock position to secure the new battery.
결론
작성자
3다른 기여자 명과 함께
Anthony Toscano
회원 가입일: 10/20/16
323 평판
안내서 3개를 작성함
UMass Dartmouth, Team 6-7, Martin Fall 2016 UMass Dartmouth, Team 6-7, Martin Fall 2016 회원
UMASSD-MARTIN-F16S6G7
3 회원들
안내서 4개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 3
지난 7일: 8
지난 30일: 19
전체 시간: 783
