주요 콘텐츠로 건너뛰기
Dell Inspiron E1505 Hard drive Replacement
필요한 것
  1. Dell Inspiron E1505 Hard drive Replacement, Battery: 1 단계, 이미지 1/3 Dell Inspiron E1505 Hard drive Replacement, Battery: 1 단계, 이미지 2/3 Dell Inspiron E1505 Hard drive Replacement, Battery: 1 단계, 이미지 3/3
    • Save work and shut down computer.
    • Shut Lid and flip computer.
    • Disconnect charger. (If applicable)
    • Slide the battery eject and remove battery.
  2. Dell Inspiron E1505 Hard drive Replacement, Removing the drive: 2 단계, 이미지 1/3 Dell Inspiron E1505 Hard drive Replacement, Removing the drive: 2 단계, 이미지 2/3 Dell Inspiron E1505 Hard drive Replacement, Removing the drive: 2 단계, 이미지 3/3
    • Make sure there are no screws holding the drive in.
    • Slide the hard drive out of the laptop.
  3. Dell Inspiron E1505 Hard drive Replacement, Hard drive bracket: 3 단계, 이미지 1/3 Dell Inspiron E1505 Hard drive Replacement, Hard drive bracket: 3 단계, 이미지 2/3 Dell Inspiron E1505 Hard drive Replacement, Hard drive bracket: 3 단계, 이미지 3/3
    • Remove screws from bracket.
    • Attach bracket to new hard drive.
    • Ta-da! You did it.
결론
TMG
회원 가입일: 03/10/22
614 평판
안내서 4개 작성하였습니다
0 Comments
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 1
30일 전: 10
전체 시간: 62
