주요 콘텐츠로 건너뛰기
Dell Inspiron E1505 Optical Drive Replacement
필요한 것
  1. Dell Inspiron E1505 Optical Drive Replacement, Battery: 1 단계, 이미지 1/1
    • Before any work can be done ensure that the laptop is powered off.
    • Use either the power button on the computer or issue a shutdown from the operating system.
    • Once the device is off place the laptop on a flat surface and flip it so that the bottom is facing upwards.
  2. Dell Inspiron E1505 Optical Drive Replacement: 2 단계, 이미지 1/1
    • Locate the battery release switch on the bottom of the laptop.
    • Once located slide the switch into the unlock position.
  3. Dell Inspiron E1505 Optical Drive Replacement: 3 단계, 이미지 1/1
    • Locate the “lip” on the laptop to lift the battery outside of the compartment.
    • Once the battery is out, you will be able to find the replacement part number in order to purchase a new battery.
  4. Dell Inspiron E1505 Optical Drive Replacement: 4 단계, 이미지 1/1
    • Once the new battery has been acquired take the battery and place it in the empty battery slot.
    • Slide the switch into the lock position to secure the new battery.
  5. Dell Inspiron E1505 Optical Drive Replacement, Optical Drive: 5 단계, 이미지 1/3 Dell Inspiron E1505 Optical Drive Replacement, Optical Drive: 5 단계, 이미지 2/3 Dell Inspiron E1505 Optical Drive Replacement, Optical Drive: 5 단계, 이미지 3/3
    • Remove the back panel: Use the screwdriver to remove the screws on the back panel.
    • Lift the back panel off the laptop to expose the interior of the laptop.
    • Locate the hard drive.
  6. Dell Inspiron E1505 Optical Drive Replacement: 6 단계, 이미지 1/1
    • Remove the current optical drive.
    • Look at the model number and order the replacement if needed.
    • Insert the new optical drive in.
결론
Anthony Toscano
회원 가입일: 10/20/16
323 평판
안내서 3개 작성하였습니다
UMass Dartmouth, Team 6-7, Martin Fall 2016 UMass Dartmouth, Team 6-7, Martin Fall 2016 회원
UMASSD-MARTIN-F16S6G7
3 회원들
안내서 4개 작성하였습니다
댓글 2개
@oldturkey03 This guide is showing how to remove the ODD, not the HDD. I was wondering if I should change it. The guide is also incorrect. Only one screw is necessary to remove the ODD. I suppose I should make another and archive this...
George A. - 답글
@pccheese it's a student guide so leave it alone. Do not archive anything on this. Go ahead and create your guide and then post that as an alternative. I would give the composer of this guide the courtesy and kindly let them know.
oldturkey03 -
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 11
30일 전: 11
전체 시간: 698
