주요 콘텐츠로 건너뛰기
Dell Inspiron E1705 Optical Drive Replacement
필요한 것
  1. Dell Inspiron E1705 Optical Drive Replacement, Battery: 1 단계, 이미지 1/1
    • Make sure that the computer is turned off and is disconnected from external power source.
    • Turn it upside down and locate the battery release switch.
  2. Dell Inspiron E1705 Optical Drive Replacement: 2 단계, 이미지 1/2 Dell Inspiron E1705 Optical Drive Replacement: 2 단계, 이미지 2/2
    • While holding the switch in the open position, lift out the battery.
    • If you plan to work on any internal laptop components, press and hold the power button for 5 seconds. This will dissipate any residual charge on the motherboard to prevent electrical shock when you begin to handle it.
  3. Dell Inspiron E1705 Optical Drive Replacement, Optical Drive: 3 단계, 이미지 1/1
    • Locate and remove the screw shown
    • It is labeled with a lock symbol
  4. Dell Inspiron E1705 Optical Drive Replacement: 4 단계, 이미지 1/2 Dell Inspiron E1705 Optical Drive Replacement: 4 단계, 이미지 2/2
    • Use the screwdriver to gently push the optical drive out
결론
다른 3명이 해당 안내서를 완성하였습니다.
Evan Fairchild
회원 가입일: 10/05/10
613 평판
안내서 4개 작성하였습니다
Cal Poly, Team 22-5, Maness Fall 2010 Cal Poly, Team 22-5, Maness Fall 2010 회원
CPSU-MANESS-F10S22G5
4 회원들
안내서 11개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 1
전체 시간: 3,901
