주요 콘텐츠로 건너뛰기
Dell Inspiron E1705 RAM Replacement
필요한 것
  1. Dell Inspiron E1705 RAM Replacement, Battery: 1 단계, 이미지 1/1
    • Make sure that the computer is turned off and is disconnected from external power source.
    • Turn it upside down and locate the battery release switch.
    Introduction: Parts: Need to add the Fan Part Numbers
    Original equipment: CPU Fan DC28A000820, GPU Fan DC28A000920
    John Frazier - 답글
  2. Dell Inspiron E1705 RAM Replacement: 2 단계, 이미지 1/2 Dell Inspiron E1705 RAM Replacement: 2 단계, 이미지 2/2
    • While holding the switch in the open position, lift out the battery.
    • If you plan to work on any internal laptop components, press and hold the power button for 5 seconds. This will dissipate any residual charge on the motherboard to prevent electrical shock when you begin to handle it.
  3. Dell Inspiron E1705 RAM Replacement, RAM: 3 단계, 이미지 1/2 Dell Inspiron E1705 RAM Replacement, RAM: 3 단계, 이미지 2/2
    • Turn the computer over, screen closed, so that the underside is showing
    • Locate the two screws as shown and remove them.
    • Use a small phillips head screwdriver
  4. Dell Inspiron E1705 RAM Replacement: 4 단계, 이미지 1/3 Dell Inspiron E1705 RAM Replacement: 4 단계, 이미지 2/3 Dell Inspiron E1705 RAM Replacement: 4 단계, 이미지 3/3
    • Remove plastic cover carefully
    • There will be two RAM sticks as shown
    • Using your fingers, pull the sides apart that are holding the RAM in place. This will release the RAM.
  5. Dell Inspiron E1705 RAM Replacement: 5 단계, 이미지 1/1
    • Carefully remove old/damaged RAM sticks and replace with new ones.
결론
다른 5명이 해당 안내서를 완성하였습니다.
Evan Fairchild
회원 가입일: 10/05/10
613 평판
안내서 4개 작성하였습니다
Cal Poly, Team 22-5, Maness Fall 2010 Cal Poly, Team 22-5, Maness Fall 2010 회원
CPSU-MANESS-F10S22G5
4 회원들
안내서 11개 작성하였습니다
댓글 한 개
If upgrading RAM, a black DOS based screen will show stating "the amount of RAM in system has changed", wait 1minute and the computer will beep and prompt for F1 (boot normally) or F2 (run system setup utility). Pressing F2 and waiting some time will allow the computer to reconfigure and then boot into Windows normally.
bejtommywy - 답글
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 4
30일 전: 17
전체 시간: 8,145
