주요 콘텐츠로 건너뛰기
Dell Inspiron E1705 Upper Case and Screen Replacement
필요한 것
  1. Dell Inspiron E1705 Upper Case and Screen Replacement, Upper Case and Screen: 1 단계, 이미지 1/1
    • Use a spudger to remove the six rubber nibs and 2 plastic pieces on the bezel of the display.
    • Remove the eight Phillips #0 screws hidden under the rubber nibs and plastic pieces.
  2. Dell Inspiron E1705 Upper Case and Screen Replacement: 2 단계, 이미지 1/2 Dell Inspiron E1705 Upper Case and Screen Replacement: 2 단계, 이미지 2/2
    • Pry the plastic bezel from the back plate using a plastic opening tool.
    • Remove the plastic bezel entirely and set it aside.
  3. Dell Inspiron E1705 Upper Case and Screen Replacement: 3 단계, 이미지 1/2 Dell Inspiron E1705 Upper Case and Screen Replacement: 3 단계, 이미지 2/2
    • Remove the 4 screws along the left and right sides of the screen. There are 8 screws in total.
  4. Dell Inspiron E1705 Upper Case and Screen Replacement: 4 단계, 이미지 1/2 Dell Inspiron E1705 Upper Case and Screen Replacement: 4 단계, 이미지 2/2
    • Use the spudger to separate the screen from the back case.
    • Hold the screen in one hand and tilt the back case away from you.
    • The screen is connected to the back case by two leads.
  5. Dell Inspiron E1705 Upper Case and Screen Replacement: 5 단계, 이미지 1/2 Dell Inspiron E1705 Upper Case and Screen Replacement: 5 단계, 이미지 2/2
    • Remove the two leads from the screen. They will stay connected to the computer.
    • Do not touch the white tape on your replacement monitor.
    • Remove the screen carefully.
결론
다른 9명이 해당 안내서를 완성하였습니다.
Evan Fairchild
회원 가입일: 10/05/10
613 평판
안내서 4개 작성하였습니다
Cal Poly, Team 22-5, Maness Fall 2010 Cal Poly, Team 22-5, Maness Fall 2010 회원
CPSU-MANESS-F10S22G5
4 회원들
안내서 11개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 2
30일 전: 19
전체 시간: 7,015
