소개
In this guide, we will be showing you how to remove and replace the Display Assembly.
필요한 것
Disconnect the display cable from the connector on the system board and remove it from the routing guide.
Remove the four screws (two on each side) that secure the display assembly to the computer base.
Place the NEW display assembly in position and replace the four screws (two on each side) that secure the display assembly to the computer base.
Route the display cable into the routing guide and connect the cable to the connector on the system board.
Connect the Mini-Card antenna cables to the connectors on the Mini- Card.
Turn the computer over and replace the two screws at the bottom of the computer.
다른 한 분이 해당 안내서를 완성하였습니다.
