주요 콘텐츠로 건너뛰기
Dell Inspiron M5010 Fan/Heatsink Replacement
필요한 것
  1. Dell Inspiron M5010 Fan/Heatsink Replacement, Remove keyboard retaining screw: 1 단계, 이미지 1개 중 1개
    • Remove Keyboard retaining screw from bottom of laptop.
  2. Dell Inspiron M5010 Fan/Heatsink Replacement: 2 단계, 이미지 3개 중 1개 Dell Inspiron M5010 Fan/Heatsink Replacement: 2 단계, 이미지 3개 중 2개 Dell Inspiron M5010 Fan/Heatsink Replacement: 2 단계, 이미지 3개 중 3개
    • Insert the 6 inch metal ruler, or another flat object into the holes in the top left of the keyboard, the top middle of the keyboard, and the top right of the keyboard to release the keyboard from the computer.
    • There are a number of screws on the bottom that required to be removed prior to the keyboard being able to be lifted up.
  3. Dell Inspiron M5010 Fan/Heatsink Replacement: 3 단계, 이미지 1개 중 1개
    • Lift the keyboard up slightly and push forward in order to release bottom tabs.
  4. Dell Inspiron M5010 Fan/Heatsink Replacement: 4 단계, 이미지 1개 중 1개
    • Pull the black tab up and then pull left on keyboard plug to release keyboard.
  5. Dell Inspiron M5010 Fan/Heatsink Replacement, Palm Rest: 5 단계, 이미지 1개 중 1개
    • Flip the laptop, so the bottom of the laptop is facing up.
    • Remove the seven 6.0mm Phillip #000 screws indicated using the Phillips #000 screwdriver.
  6. Dell Inspiron M5010 Fan/Heatsink Replacement: 6 단계, 이미지 2개 중 1개 Dell Inspiron M5010 Fan/Heatsink Replacement: 6 단계, 이미지 2개 중 2개
    • Flip the laptop back over, so that the top of the laptop is facing up.
    • Open the laptop.
    • Remove all of the indicated 6.0 mm screws with the Phillips #000 screwdriver.
  7. Dell Inspiron M5010 Fan/Heatsink Replacement: 7 단계, 이미지 1개 중 1개
    • Unplug the palm rest cables by lifting the black tab up and then pulling on the blue tabs.
  8. Dell Inspiron M5010 Fan/Heatsink Replacement: 8 단계, 이미지 3개 중 1개 Dell Inspiron M5010 Fan/Heatsink Replacement: 8 단계, 이미지 3개 중 2개 Dell Inspiron M5010 Fan/Heatsink Replacement: 8 단계, 이미지 3개 중 3개
    • Carefully unsnap and remove the palm rest.
    • Place your fingers inside the large circle in the lower right corner to get a good grip.
  9. Dell Inspiron M5010 Fan/Heatsink Replacement, Fan/Heatsink: 9 단계, 이미지 1개 중 1개
    • Flip the laptop over so the bottom is facing up.
    • Remove the indicated 17 6mm Phillips #000 screws on the back of the laptop using the Phillips #000 screwdriver.
  10. Dell Inspiron M5010 Fan/Heatsink Replacement: 10 단계, 이미지 2개 중 1개 Dell Inspiron M5010 Fan/Heatsink Replacement: 10 단계, 이미지 2개 중 2개
    • Pull the clear tab attached to the hard drive and gently lift up the hard drive to remove it.
  11. Dell Inspiron M5010 Fan/Heatsink Replacement: 11 단계, 이미지 2개 중 1개 Dell Inspiron M5010 Fan/Heatsink Replacement: 11 단계, 이미지 2개 중 2개
    • Flip the laptop back over and unplug the Speakers.
  12. Dell Inspiron M5010 Fan/Heatsink Replacement: 12 단계, 이미지 2개 중 1개 Dell Inspiron M5010 Fan/Heatsink Replacement: 12 단계, 이미지 2개 중 2개
    • Unplug the SD Card Slot.
    • You do not have to remove the SD Card Slot, just unplug it.
  13. Dell Inspiron M5010 Fan/Heatsink Replacement: 13 단계, 이미지 1개 중 1개
    • Unplug the USB/VGA cable.
  14. Dell Inspiron M5010 Fan/Heatsink Replacement: 14 단계, 이미지 1개 중 1개
    • Remove the 4 mm Phillips #000 motherboard screws using the Phillips #000 screwdriver.
  15. Dell Inspiron M5010 Fan/Heatsink Replacement: 15 단계, 이미지 1개 중 1개
    • Remove the 4 indicated 6 mm Phillips #000 front hinge screws with the Phillips #000 screwdriver.
  16. Dell Inspiron M5010 Fan/Heatsink Replacement: 16 단계, 이미지 2개 중 1개 Dell Inspiron M5010 Fan/Heatsink Replacement: 16 단계, 이미지 2개 중 2개
    • Unplug the Wireless Antenna cables.
  17. Dell Inspiron M5010 Fan/Heatsink Replacement: 17 단계, 이미지 3개 중 1개 Dell Inspiron M5010 Fan/Heatsink Replacement: 17 단계, 이미지 3개 중 2개 Dell Inspiron M5010 Fan/Heatsink Replacement: 17 단계, 이미지 3개 중 3개
    • Unplug the LCD cable.
    • Lift the screen from the computer.
  18. Dell Inspiron M5010 Fan/Heatsink Replacement: 18 단계, 이미지 1개 중 1개
    • Remove the Middle Cover.
  19. Dell Inspiron M5010 Fan/Heatsink Replacement: 19 단계, 이미지 1개 중 1개
    • Remove the Motherboard.
  20. Dell Inspiron M5010 Fan/Heatsink Replacement: 20 단계, 이미지 2개 중 1개 Dell Inspiron M5010 Fan/Heatsink Replacement: 20 단계, 이미지 2개 중 2개
    • Unplug the fan.
  21. Dell Inspiron M5010 Fan/Heatsink Replacement: 21 단계, 이미지 2개 중 1개 Dell Inspiron M5010 Fan/Heatsink Replacement: 21 단계, 이미지 2개 중 2개
    • Remove all 4 of the 6 mm Phillips #000 Heatsink screws with the Phillips #000 screwdriver.
  22. Dell Inspiron M5010 Fan/Heatsink Replacement: 22 단계, 이미지 1개 중 1개
    • Lift the Heatsink from the Motherboard.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
작성자
3다른 기여자 명과 함께
April Poucher
회원 가입일: 10/13/14
1,164 평판
안내서 10개를 작성함
Clemson, Team 1-5, Benson Fall 2014 Clemson, Team 1-5, Benson Fall 2014 회원
CLEM-BENSON-F14S1G5
4 회원들
안내서 11개를 작성함
댓글 0개
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 7
지난 30일: 11
전체 시간: 1,021
