주요 콘텐츠로 건너뛰기
Dell Inspiron M5010 RAM Replacement
필요한 것
  1. Dell Inspiron M5010 RAM Replacement, Battery: 1 단계, 이미지 1/2 Dell Inspiron M5010 RAM Replacement, Battery: 1 단계, 이미지 2/2
    • Make sure laptop is powered off before removing the battery.
    • Slide both arrow tabs towards the outer edge of the computer to release the battery.
    • Battery is not shown.
  2. Dell Inspiron M5010 RAM Replacement, RAM: 2 단계, 이미지 1/2 Dell Inspiron M5010 RAM Replacement, RAM: 2 단계, 이미지 2/2
    • Using the Phillips #000 screwdriver, loosen the screw holding in the back cover.
    • Then, lift up the back cover to remove it.
  3. Dell Inspiron M5010 RAM Replacement: 3 단계, 이미지 1/3 Dell Inspiron M5010 RAM Replacement: 3 단계, 이미지 2/3 Dell Inspiron M5010 RAM Replacement: 3 단계, 이미지 3/3
    • Snap open the top memory clips and remove the memory drive they hold in.
  4. Dell Inspiron M5010 RAM Replacement: 4 단계, 이미지 1/3 Dell Inspiron M5010 RAM Replacement: 4 단계, 이미지 2/3 Dell Inspiron M5010 RAM Replacement: 4 단계, 이미지 3/3
    • Snap open the bottom memory clips and remove the memory drive they hold in.
  5. Dell Inspiron M5010 RAM Replacement: 5 단계, 이미지 1/1
    • The laptop computer should look like this once both memory cards are removed.
결론
April Poucher
회원 가입일: 10/13/14
1,164 평판
안내서 10개 작성하였습니다
Clemson, Team 1-5, Benson Fall 2014 Clemson, Team 1-5, Benson Fall 2014 회원
CLEM-BENSON-F14S1G5
4 회원들
안내서 11개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 1
30일 전: 9
전체 시간: 422
