주요 콘텐츠로 건너뛰기
Dell Inspiron M5010 SD Card Slot Replacement
필요한 것
  1. Dell Inspiron M5010 SD Card Slot Replacement, Battery: 1 단계, 이미지 2개 중 1개 Dell Inspiron M5010 SD Card Slot Replacement, Battery: 1 단계, 이미지 2개 중 2개
    • Make sure laptop is powered off before removing the battery.
    • Slide both arrow tabs towards the outer edge of the computer to release the battery.
    • Battery is not shown.
  2. Dell Inspiron M5010 SD Card Slot Replacement, Remove keyboard retaining screw: 2 단계, 이미지 1개 중 1개
    • Remove Keyboard retaining screw from bottom of laptop.
  3. Dell Inspiron M5010 SD Card Slot Replacement: 3 단계, 이미지 3개 중 1개 Dell Inspiron M5010 SD Card Slot Replacement: 3 단계, 이미지 3개 중 2개 Dell Inspiron M5010 SD Card Slot Replacement: 3 단계, 이미지 3개 중 3개
    • Insert the 6 inch metal ruler, or another flat object into the holes in the top left of the keyboard, the top middle of the keyboard, and the top right of the keyboard to release the keyboard from the computer.
    • There are a number of screws on the bottom that required to be removed prior to the keyboard being able to be lifted up.
  4. Dell Inspiron M5010 SD Card Slot Replacement: 4 단계, 이미지 1개 중 1개
    • Lift the keyboard up slightly and push forward in order to release bottom tabs.
  5. Dell Inspiron M5010 SD Card Slot Replacement: 5 단계, 이미지 1개 중 1개
    • Pull the black tab up and then pull left on keyboard plug to release keyboard.
  6. Dell Inspiron M5010 SD Card Slot Replacement, Palm Rest: 6 단계, 이미지 1개 중 1개
    • Flip the laptop, so the bottom of the laptop is facing up.
    • Remove the seven 6.0mm Phillip #000 screws indicated using the Phillips #000 screwdriver.
  7. Dell Inspiron M5010 SD Card Slot Replacement: 7 단계, 이미지 2개 중 1개 Dell Inspiron M5010 SD Card Slot Replacement: 7 단계, 이미지 2개 중 2개
    • Flip the laptop back over, so that the top of the laptop is facing up.
    • Open the laptop.
    • Remove all of the indicated 6.0 mm screws with the Phillips #000 screwdriver.
  8. Dell Inspiron M5010 SD Card Slot Replacement: 8 단계, 이미지 1개 중 1개
    • Unplug the palm rest cables by lifting the black tab up and then pulling on the blue tabs.
  9. Dell Inspiron M5010 SD Card Slot Replacement: 9 단계, 이미지 3개 중 1개 Dell Inspiron M5010 SD Card Slot Replacement: 9 단계, 이미지 3개 중 2개 Dell Inspiron M5010 SD Card Slot Replacement: 9 단계, 이미지 3개 중 3개
    • Carefully unsnap and remove the palm rest.
    • Place your fingers inside the large circle in the lower right corner to get a good grip.
  10. Dell Inspiron M5010 SD Card Slot Replacement, SD Card Slot: 10 단계, 이미지 3개 중 1개 Dell Inspiron M5010 SD Card Slot Replacement, SD Card Slot: 10 단계, 이미지 3개 중 2개 Dell Inspiron M5010 SD Card Slot Replacement, SD Card Slot: 10 단계, 이미지 3개 중 3개
    • Unplug the SD Card Slot cable.
    • Gently lift the SD Card Slot from the computer.
결론
작성자
3다른 기여자 명과 함께
April Poucher
회원 가입일: 10/13/14
1,164 평판
안내서 10개를 작성함
Clemson, Team 1-5, Benson Fall 2014 Clemson, Team 1-5, Benson Fall 2014 회원
CLEM-BENSON-F14S1G5
4 회원들
안내서 11개를 작성함
댓글 0개
댓글 쓰기
조회 통계:
지난 24시간: 1
지난 7일: 7
지난 30일: 13
전체 시간: 484
