주요 콘텐츠로 건너뛰기
Dell Inspiron M5110 Display Assembly Replacement
필요한 것
  1. Dell Inspiron M5110 Display Assembly Replacement, Battery: 1 단계, 이미지 1/1
    • Shut down the computer and turn it upside down.
  2. Dell Inspiron M5110 Display Assembly Replacement: 2 단계, 이미지 1/1
    • Slide both of the battery release latches on the bottom of the device in towards the center of the computer.
  3. Dell Inspiron M5110 Display Assembly Replacement: 3 단계, 이미지 1/1
    • Slide and lift the battery up and out from the device.
  4. Dell Inspiron M5110 Display Assembly Replacement, Keyboard: 4 단계, 이미지 1/1
    • Open the computer and push the screen back as far as possible.
  5. Dell Inspiron M5110 Display Assembly Replacement: 5 단계, 이미지 1/1
    • Slide a plastic opening tool into the slots on the top of the keyboard.
  6. Dell Inspiron M5110 Display Assembly Replacement: 6 단계, 이미지 1/1
    • Pry the keyboard away from the device using the plastic opening tool.
  7. Dell Inspiron M5110 Display Assembly Replacement: 7 단계, 이미지 1/1
    • Lift and slide the keyboard towards the screen to remove the tabs on the keyboard from the slots on the palmrest.
  8. Dell Inspiron M5110 Display Assembly Replacement: 8 단계, 이미지 1/1
    • Flip the keyboard over and place it on the front of the device making sure not to pull out the keyboard cable.
  9. Dell Inspiron M5110 Display Assembly Replacement: 9 단계, 이미지 1/1
    • Lift up the connector latch and remove the keyboard cable. The keyboard is now free from the device.
  10. Dell Inspiron M5110 Display Assembly Replacement, Palmrest: 10 단계, 이미지 1/1
    • Turn the computer over and remove the six screws that secure the palmrest assembly
  11. Dell Inspiron M5110 Display Assembly Replacement: 11 단계, 이미지 1/1
    • Turn the computer over and open the display as far as possible and remove the four 5 mm Phillips # 0 screw holding the palmrest in place.
  12. Dell Inspiron M5110 Display Assembly Replacement: 12 단계, 이미지 1/2 Dell Inspiron M5110 Display Assembly Replacement: 12 단계, 이미지 2/2
    • Disconnect the power button board cable, touch pad cable and the hot key board cable from the connectors.
  13. Dell Inspiron M5110 Display Assembly Replacement: 13 단계, 이미지 1/2 Dell Inspiron M5110 Display Assembly Replacement: 13 단계, 이미지 2/2
    • Use a plastic opening tool to carefully pry out the palmrest assembly and lift it off the computer base.
  14. Dell Inspiron M5110 Display Assembly Replacement, Display Assembly: 14 단계, 이미지 1/1
    • Turn the device over and then remove the two 5 mm Phillips #0 screws that keeps the display assembly to the base and then flip the device.
  15. Dell Inspiron M5110 Display Assembly Replacement: 15 단계, 이미지 1/1
    • Disconnect the display antenna cable from the Mini Card.
  16. Dell Inspiron M5110 Display Assembly Replacement: 16 단계, 이미지 1/1
    • Disconnect the LCD display cable and touch screen cable.
  17. Dell Inspiron M5110 Display Assembly Replacement: 17 단계, 이미지 1/2 Dell Inspiron M5110 Display Assembly Replacement: 17 단계, 이미지 2/2
    • There are two 5 mm Phillips # 0 screws on each hinge.
    • Unscrew the four 5 mm Phillips # 0 screws holding the hinge that keeps the monitor in place.
  18. Dell Inspiron M5110 Display Assembly Replacement: 18 단계, 이미지 1/1
    • Lift the display off the computer base.
결론
Maxwell Dumerant
회원 가입일: 10/18/16
19 평판
안내서 1개 작성함
UMass Dartmouth, Team 4-3, Catania Fall 2016 UMass Dartmouth, Team 4-3, Catania Fall 2016 회원
UMASSD-CATANIA-F16S4G3
3 회원들
안내서 8개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 3
30일 전: 9
전체 시간: 248
