주요 콘텐츠로 건너뛰기
Dell Inspiron M5110 Fan Compartment Replacement
필요한 것
  1. Dell Inspiron M5110 Fan Compartment Replacement, Battery: 1 단계, 이미지 1개 중 1개
    • Shut down the computer and turn it upside down.
  2. Dell Inspiron M5110 Fan Compartment Replacement: 2 단계, 이미지 1개 중 1개
    • Slide both of the battery release latches on the bottom of the device in towards the center of the computer.
  3. Dell Inspiron M5110 Fan Compartment Replacement: 3 단계, 이미지 1개 중 1개
    • Slide and lift the battery up and out from the device.
  4. Dell Inspiron M5110 Fan Compartment Replacement, Module Cover: 4 단계, 이미지 2개 중 1개 Dell Inspiron M5110 Fan Compartment Replacement, Module Cover: 4 단계, 이미지 2개 중 2개
    • Remove the 5 mm Phillips # 0 screw in the middle of the device.
  5. Dell Inspiron M5110 Fan Compartment Replacement: 5 단계, 이미지 1개 중 1개
    • Remove the module cover pressing in the release tabs and pulling the cover up and away from the base of the device.
  6. Dell Inspiron M5110 Fan Compartment Replacement, Optical Drive: 6 단계, 이미지 2개 중 1개 Dell Inspiron M5110 Fan Compartment Replacement, Optical Drive: 6 단계, 이미지 2개 중 2개
    • Insert a small screwdriver into the hole and slide the optical drive away from the center of the device. This will slide the optical assembly out from the side of the device.
  7. Dell Inspiron M5110 Fan Compartment Replacement: 7 단계, 이미지 1개 중 1개
    • Slide the optical drive assembly the rest of the way out of the device.
  8. Dell Inspiron M5110 Fan Compartment Replacement, Fan Compartment: 8 단계, 이미지 1개 중 1개
    • Flip the laptop over and open it to reveal the keyboard.
    • Open the computer and push the screen back as far as possible.
  9. Dell Inspiron M5110 Fan Compartment Replacement: 9 단계, 이미지 1개 중 1개
    • Slide a plastic opening tool into the slots on the top of the keyboard.
  10. Dell Inspiron M5110 Fan Compartment Replacement: 10 단계, 이미지 1개 중 1개
    • Pry the keyboard away from the device using the plastic opening tool.
  11. Dell Inspiron M5110 Fan Compartment Replacement: 11 단계, 이미지 1개 중 1개
    • Lift and slide the keyboard towards the screen to remove the tabs on the keyboard from the slots on the palmrest.
  12. Dell Inspiron M5110 Fan Compartment Replacement: 12 단계, 이미지 1개 중 1개
    • Flip the keyboard over and place it on the front of the device making sure not to pull out the keyboard-cable.
  13. Dell Inspiron M5110 Fan Compartment Replacement: 13 단계, 이미지 1개 중 1개
    • Lift up the connector latch and remove the keyboard cable. The keyboard is now free from the device.
  14. Dell Inspiron M5110 Fan Compartment Replacement: 14 단계, 이미지 1개 중 1개
    • Turn the computer over and remove the twelve 5 mm Phillips # 0 screws on the back of the device.
  15. Dell Inspiron M5110 Fan Compartment Replacement: 15 단계, 이미지 1개 중 1개
    • Turn the computer over and open the display as far as possible and remove the four 5 mm Phillips # 0 screw holding the palmrest in place.
  16. Dell Inspiron M5110 Fan Compartment Replacement: 16 단계, 이미지 2개 중 1개 Dell Inspiron M5110 Fan Compartment Replacement: 16 단계, 이미지 2개 중 2개
    • Disconnect the power button board cable, touch pad cable and the hot key board cable from the connectors.
  17. Dell Inspiron M5110 Fan Compartment Replacement: 17 단계, 이미지 2개 중 1개 Dell Inspiron M5110 Fan Compartment Replacement: 17 단계, 이미지 2개 중 2개
    • Use a plastic opening tool to carefully pry out the palmrest assembly and lift it off the computer base.
  18. Dell Inspiron M5110 Fan Compartment Replacement: 18 단계, 이미지 1개 중 1개
    • Unscrew the five 5 mm Phillips # 0 screws located in the red circles, found on the system board.
  19. Dell Inspiron M5110 Fan Compartment Replacement: 19 단계, 이미지 2개 중 1개 Dell Inspiron M5110 Fan Compartment Replacement: 19 단계, 이미지 2개 중 2개
    • Unplug the small, green, rectangular Bluetooth receptor chip attached towards the bottom right hand corner of the system board.
    • Grasp the chip by placing your forefinger under the chip and thumb on the top, lightly pulling the chip upwards away from the device.
  20. Dell Inspiron M5110 Fan Compartment Replacement: 20 단계, 이미지 2개 중 1개 Dell Inspiron M5110 Fan Compartment Replacement: 20 단계, 이미지 2개 중 2개
    이 단계에 사용된 도구:
    • Unplug the small white cable connected to the fan in the upper left hand corner and to the speaker in the lower right hand corner of the device.
    • Use tweezers to unplug the cables if they are hard to remove by hand or if you cannot grasp them.
  21. Dell Inspiron M5110 Fan Compartment Replacement: 21 단계, 이미지 2개 중 1개 Dell Inspiron M5110 Fan Compartment Replacement: 21 단계, 이미지 2개 중 2개
    • Disconnect the black and white antenna cables from the Mini Card.
  22. Dell Inspiron M5110 Fan Compartment Replacement: 22 단계, 이미지 1개 중 1개
    • Unplug the rectangular black LCD cable attached to the main board towards the upper left hand corner.
  23. Dell Inspiron M5110 Fan Compartment Replacement: 23 단계, 이미지 2개 중 1개 Dell Inspiron M5110 Fan Compartment Replacement: 23 단계, 이미지 2개 중 2개
    • Remove the SD card by pressing the SD card slot, on the side of the device, inside the device until you hear a click. Then release your pressure on the slot then gently slide the SD card out.
  24. Dell Inspiron M5110 Fan Compartment Replacement: 24 단계, 이미지 2개 중 1개 Dell Inspiron M5110 Fan Compartment Replacement: 24 단계, 이미지 2개 중 2개
    • There are two 5 mm Phillips # 0 screws on each hinge.
    • Unscrew the four 5 mm Phillips # 0 screws holding the hinge that keeps the monitor in place.
  25. Dell Inspiron M5110 Fan Compartment Replacement: 25 단계, 이미지 3개 중 1개 Dell Inspiron M5110 Fan Compartment Replacement: 25 단계, 이미지 3개 중 2개 Dell Inspiron M5110 Fan Compartment Replacement: 25 단계, 이미지 3개 중 3개
    • Remove the monitor carefully.
    • Pull up and away on the black hinge cover with moderate force to release from the device.
  26. Dell Inspiron M5110 Fan Compartment Replacement: 26 단계, 이미지 3개 중 1개 Dell Inspiron M5110 Fan Compartment Replacement: 26 단계, 이미지 3개 중 2개 Dell Inspiron M5110 Fan Compartment Replacement: 26 단계, 이미지 3개 중 3개
    • Remove the system board from the laptop.
    • Disconnect the two minor boards, the VGA/Power Board on the left, and the I/O Board on the right, attatched to the system board.
    • Flip the system board over revealing the fan compartment and the hard drive.
  27. Dell Inspiron M5110 Fan Compartment Replacement: 27 단계, 이미지 1개 중 1개
    • Remove the fan compartment from the main board by turning the three gold Phillips # 0 screws until they dislodge from the system board.
    • The gold screws will spin continuously when they are dislodged.
    • The three gold screws will not seperate from the the fan compartment.
    • Unscrew the two silver 2 cm Phillips # 0 screws.
  28. Dell Inspiron M5110 Fan Compartment Replacement: 28 단계, 이미지 1개 중 1개
    • Lift the fan compartment up to remove it from the systemboard.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
작성자
3다른 기여자 명과 함께
Larain
회원 가입일: 10/26/16
387 평판
안내서 3개를 작성함
UMass Dartmouth, Team 4-3, Catania Fall 2016 UMass Dartmouth, Team 4-3, Catania Fall 2016 회원
UMASSD-CATANIA-F16S4G3
3 회원들
안내서 8개를 작성함
댓글 0개
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 0
지난 30일: 10
전체 시간: 267
