주요 콘텐츠로 건너뛰기
Dell Inspiron M5110 Keyboard Replacement
필요한 것
  1. Dell Inspiron M5110 Keyboard Replacement, Battery: 1 단계, 이미지 1/1
    • Shut down the computer and turn it upside down.
  2. Dell Inspiron M5110 Keyboard Replacement: 2 단계, 이미지 1/1
    • Slide both of the battery release latches on the bottom of the device in towards the center of the computer.
  3. Dell Inspiron M5110 Keyboard Replacement: 3 단계, 이미지 1/1
    • Slide and lift the battery up and out from the device.
  4. Dell Inspiron M5110 Keyboard Replacement, Keyboard: 4 단계, 이미지 1/1
    • Open the computer and push the screen back as far as possible.
  5. Dell Inspiron M5110 Keyboard Replacement: 5 단계, 이미지 1/1
    • Slide a plastic opening tool into the slots on the top of the keyboard.
  6. Dell Inspiron M5110 Keyboard Replacement: 6 단계, 이미지 1/1
    • Pry the keyboard away from the device using the plastic opening tool.
  7. Dell Inspiron M5110 Keyboard Replacement: 7 단계, 이미지 1/1
    • Lift and slide the keyboard towards the screen to remove the tabs on the keyboard from the slots on the palmrest.
  8. Dell Inspiron M5110 Keyboard Replacement: 8 단계, 이미지 1/1
    • Flip the keyboard over and place it on the front of the device making sure not to pull out the keyboard cable.
  9. Dell Inspiron M5110 Keyboard Replacement: 9 단계, 이미지 1/1
    • Lift up the connector latch and remove the keyboard cable. The keyboard is now free from the device.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
Cody Flynn
회원 가입일: 10/18/16
331 평판
안내서 4개 작성하였습니다
UMass Dartmouth, Team 4-3, Catania Fall 2016 UMass Dartmouth, Team 4-3, Catania Fall 2016 회원
UMASSD-CATANIA-F16S4G3
3 회원들
안내서 8개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 1
30일 전: 7
전체 시간: 270
