주요 콘텐츠로 건너뛰기
Dell Inspiron M5110 Palmrest Replacement
필요한 것
  1. Dell Inspiron M5110 Palmrest Replacement, Battery: 1 단계, 이미지 1개 중 1개
    • Shut down the computer and turn it upside down.
  2. Dell Inspiron M5110 Palmrest Replacement: 2 단계, 이미지 1개 중 1개
    • Slide both of the battery release latches on the bottom of the device in towards the center of the computer.
  3. Dell Inspiron M5110 Palmrest Replacement: 3 단계, 이미지 1개 중 1개
    • Slide and lift the battery up and out from the device.
  4. Dell Inspiron M5110 Palmrest Replacement, Keyboard: 4 단계, 이미지 1개 중 1개
    • Open the computer and push the screen back as far as possible.
  5. Dell Inspiron M5110 Palmrest Replacement: 5 단계, 이미지 1개 중 1개
    • Slide a plastic opening tool into the slots on the top of the keyboard.
  6. Dell Inspiron M5110 Palmrest Replacement: 6 단계, 이미지 1개 중 1개
    • Pry the keyboard away from the device using the plastic opening tool.
  7. Dell Inspiron M5110 Palmrest Replacement: 7 단계, 이미지 1개 중 1개
    • Lift and slide the keyboard towards the screen to remove the tabs on the keyboard from the slots on the palmrest.
  8. Dell Inspiron M5110 Palmrest Replacement: 8 단계, 이미지 1개 중 1개
    • Flip the keyboard over and place it on the front of the device making sure not to pull out the keyboard cable.
  9. Dell Inspiron M5110 Palmrest Replacement: 9 단계, 이미지 1개 중 1개
    • Lift up the connector latch and remove the keyboard cable. The keyboard is now free from the device.
  10. Dell Inspiron M5110 Palmrest Replacement, Palmrest: 10 단계, 이미지 1개 중 1개
    • Turn the computer over and remove the six screws that secure the palmrest assembly
  11. Dell Inspiron M5110 Palmrest Replacement: 11 단계, 이미지 1개 중 1개
    • Turn the computer over and open the display as far as possible and remove the four 5 mm Phillips # 0 screw holding the palmrest in place.
  12. Dell Inspiron M5110 Palmrest Replacement: 12 단계, 이미지 2개 중 1개 Dell Inspiron M5110 Palmrest Replacement: 12 단계, 이미지 2개 중 2개
    • Disconnect the power button board cable, touch pad cable and the hot key board cable from the connectors.
  13. Dell Inspiron M5110 Palmrest Replacement: 13 단계, 이미지 2개 중 1개 Dell Inspiron M5110 Palmrest Replacement: 13 단계, 이미지 2개 중 2개
    • Use a plastic opening tool to carefully pry out the palmrest assembly and lift it off the computer base.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
작성자
3다른 기여자 명과 함께
Larain
회원 가입일: 10/26/16
387 평판
안내서 3개를 작성함
UMass Dartmouth, Team 4-3, Catania Fall 2016 UMass Dartmouth, Team 4-3, Catania Fall 2016 회원
UMASSD-CATANIA-F16S4G3
3 회원들
안내서 8개를 작성함
댓글 0개
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 1
지난 30일: 11
전체 시간: 199
