주요 콘텐츠로 건너뛰기
Dell Inspiron M531R-5535 Fan Replacement
필요한 것
  1. Dell Inspiron M531R-5535 Fan Replacement, Fan: 1 단계, 이미지 1/3 Dell Inspiron M531R-5535 Fan Replacement, Fan: 1 단계, 이미지 2/3 Dell Inspiron M531R-5535 Fan Replacement, Fan: 1 단계, 이미지 3/3
    • Flip the laptop over and unlock the battery.
    • Lift up to remove the battery.
  2. Dell Inspiron M531R-5535 Fan Replacement: 2 단계, 이미지 1/2 Dell Inspiron M531R-5535 Fan Replacement: 2 단계, 이미지 2/2
    • Loosen the two Phillips #1 screws to remove the tray.
    • The screws stay in the tray.
  3. Dell Inspiron M531R-5535 Fan Replacement: 3 단계, 이미지 1/2 Dell Inspiron M531R-5535 Fan Replacement: 3 단계, 이미지 2/2
    • Unscrew the 3.6mm Phillips #1 screw.
    • Slide the CD Drive out.
  4. Dell Inspiron M531R-5535 Fan Replacement: 4 단계, 이미지 1/2 Dell Inspiron M531R-5535 Fan Replacement: 4 단계, 이미지 2/2
    • Unscrew nine 5.7mm Phillips #1 screws.
    • Unscrew three 5.6mm Phillips #1 screws
    • The three 5.6mm Phillips #1 screws are thinner.
    • Then flip the laptop and open it to see the keyboard.
  5. Dell Inspiron M531R-5535 Fan Replacement: 5 단계, 이미지 1/2 Dell Inspiron M531R-5535 Fan Replacement: 5 단계, 이미지 2/2
    • Use a nylon spudger or plastic opening tool to press into the highlighted keyboard latches.
  6. Dell Inspiron M531R-5535 Fan Replacement: 6 단계, 이미지 1/3 Dell Inspiron M531R-5535 Fan Replacement: 6 단계, 이미지 2/3 Dell Inspiron M531R-5535 Fan Replacement: 6 단계, 이미지 3/3
    • Lift up the keyboard.
    • Lift up on the black ZIF tab and pull the keyboard ribbon cable free.
  7. Dell Inspiron M531R-5535 Fan Replacement: 7 단계, 이미지 1/2 Dell Inspiron M531R-5535 Fan Replacement: 7 단계, 이미지 2/2
    • Unscrew the five 5.6mm Phillips #1 screws.
    • Unscrew the two 3.6mm Phillips #1 screws.
  8. Dell Inspiron M531R-5535 Fan Replacement: 8 단계, 이미지 1/2 Dell Inspiron M531R-5535 Fan Replacement: 8 단계, 이미지 2/2
    • Disconnect all highlighted cables.
  9. Dell Inspiron M531R-5535 Fan Replacement: 9 단계, 이미지 1/2 Dell Inspiron M531R-5535 Fan Replacement: 9 단계, 이미지 2/2
    • Using an opening tool, carefully pry open the case from the side.
  10. Dell Inspiron M531R-5535 Fan Replacement: 10 단계, 이미지 1/1
    • Unscrew the Phillips #1 screw.
    • Pull the white connector out to disconnect the cables from the motherboard.
    • Pull up on gold connectors (MHF4) to disconnect the cables connecting the WLAN card.
    • Pull up on the white flap and pull out the strip to disconnect the strip from the motherboard.
  11. Dell Inspiron M531R-5535 Fan Replacement: 11 단계, 이미지 1/1
    • Flip the motherboard over.
    • Pull the white connector out to disconnect the fan.
    • Lift the fan to remove it from the motherboard.
결론
다른 2명이 해당 안내서를 완성하였습니다.
Tony Chen
회원 가입일: 09/26/22
310 평판
안내서 2개 작성하였습니다
CSU Los Angeles, Team 6-5, Adachi Fall 2022 CSU Los Angeles, Team 6-5, Adachi Fall 2022 회원
CSULA-ADACHI-F22S6G5
3 회원들
안내서 5개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 1
30일 전: 10
전체 시간: 226
