주요 콘텐츠로 건너뛰기
Dell Inspiron Mini 10 Hard Drive Replacement
필요한 것
  1. Dell Inspiron Mini 10 Hard Drive Replacement, Battery: 1 단계, 이미지 1개 중 1개
    • To prevent injury and loss of data, ensure the device is turned off.
    • Slide the release latches out toward the edges to unlock the battery.
  2. Dell Inspiron Mini 10 Hard Drive Replacement: 2 단계, 이미지 1개 중 1개
    • Remove the battery by pulling it up and out.
  3. Dell Inspiron Mini 10 Hard Drive Replacement, Palm Rest: 3 단계, 이미지 1개 중 1개
    • Using a prying tool, gently pry the palm rest off of the palm rest bracket. Start prying from one side and slowly work your way around.
    • Carefully remove the palm rest from the computer base since it is still connected by a cable and to avoid damage to the palm rest.
  4. Dell Inspiron Mini 10 Hard Drive Replacement: 4 단계, 이미지 1개 중 1개
    • Gently pull the touchpad cable off the palm rest bracket.
    • Lift the rest of the palm rest off the computer base.
  5. Dell Inspiron Mini 10 Hard Drive Replacement, Keyboard: 5 단계, 이미지 1개 중 1개
    • Remove the three 8mm Philips 0 screws securing the keyboard.
  6. Dell Inspiron Mini 10 Hard Drive Replacement: 6 단계, 이미지 1개 중 1개
    • Turn over the device and open the display.
    • Gently pry open the keyboard with the plastic opening tool, working under the edges to release the clips.
  7. Dell Inspiron Mini 10 Hard Drive Replacement: 7 단계, 이미지 2개 중 1개 Dell Inspiron Mini 10 Hard Drive Replacement: 7 단계, 이미지 2개 중 2개
    • Lift the keyboard off of the support bracket carefully since it is still connected by a ribbon cable.
  8. Dell Inspiron Mini 10 Hard Drive Replacement: 8 단계, 이미지 2개 중 1개 Dell Inspiron Mini 10 Hard Drive Replacement: 8 단계, 이미지 2개 중 2개
    • Push the clips out on either side of the ribbon cable to release it.
    • Gently disconnect the ribbon cable by pulling on the clear tab.
    • Remove the keyboard.
  9. Dell Inspiron Mini 10 Hard Drive Replacement, Hard Drive: 9 단계, 이미지 2개 중 1개 Dell Inspiron Mini 10 Hard Drive Replacement, Hard Drive: 9 단계, 이미지 2개 중 2개
    • Remove the single 8mm screw attaching the hard-drive cage to the body of the device.
  10. Dell Inspiron Mini 10 Hard Drive Replacement: 10 단계, 이미지 2개 중 1개 Dell Inspiron Mini 10 Hard Drive Replacement: 10 단계, 이미지 2개 중 2개
    • Pull on the black tab and slide the hard-drive cage toward the USB port until is comes free.
  11. Dell Inspiron Mini 10 Hard Drive Replacement: 11 단계, 이미지 1개 중 1개
    • Unscrew the four 3mm screws, two on each side of the drive, and slide the drive free from the cage.
결론
다른 3명이 해당 안내서를 완성하였습니다.
작성자
4다른 기여자 명과 함께
Bariso Shuba
회원 가입일: 10/26/16
270 평판
안내서 3개를 작성함
UW Tacoma, Team 1-4, Rose Fall 2016 UW Tacoma, Team 1-4, Rose Fall 2016 회원
UWT-ROSE-F16S1G4
4 회원들
안내서 10개를 작성함
1가이드 댓글
On at least one Dell Inspiron 10 (mine), the hard drive is also secured by adhesive foam backing to the back cover of the laptop. This makes it impossible to remove by the method in this guide (and the service manual) without first either A) heating the back cover with a heat pad, or B) removing the palm rest bracket covering the mainboard, disengaging the clips that prevent the hard drive from being pulled upward, then prising the drive gently away from the backing. This also requires you to bend the hard drive screw bracket, but being aluminum, it can be bent back at least once. I used method B.
Anthony Stvartak - 답글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 3
지난 30일: 49
전체 시간: 8,041
