주요 콘텐츠로 건너뛰기
Dell Inspiron Mini 10 Palm Rest Bracket Replacement
필요한 것
  1. Dell Inspiron Mini 10 Palm Rest Bracket Replacement, Battery: 1 단계, 이미지 1개 중 1개
    • To prevent injury and loss of data, ensure the device is turned off.
    • Slide the release latches out toward the edges to unlock the battery.
  2. Dell Inspiron Mini 10 Palm Rest Bracket Replacement: 2 단계, 이미지 1개 중 1개
    • Remove the battery by pulling it up and out.
  3. Dell Inspiron Mini 10 Palm Rest Bracket Replacement, Keyboard: 3 단계, 이미지 1개 중 1개
    • Remove the three 8mm Philips 0 screws securing the keyboard.
  4. Dell Inspiron Mini 10 Palm Rest Bracket Replacement: 4 단계, 이미지 1개 중 1개
    • Turn over the device and open the display.
    • Gently pry open the keyboard with the plastic opening tool, working under the edges to release the clips.
  5. Dell Inspiron Mini 10 Palm Rest Bracket Replacement: 5 단계, 이미지 2개 중 1개 Dell Inspiron Mini 10 Palm Rest Bracket Replacement: 5 단계, 이미지 2개 중 2개
    • Lift the keyboard off of the support bracket carefully since it is still connected by a ribbon cable.
  6. Dell Inspiron Mini 10 Palm Rest Bracket Replacement: 6 단계, 이미지 2개 중 1개 Dell Inspiron Mini 10 Palm Rest Bracket Replacement: 6 단계, 이미지 2개 중 2개
    • Push the clips out on either side of the ribbon cable to release it.
    • Gently disconnect the ribbon cable by pulling on the clear tab.
    • Remove the keyboard.
  7. Dell Inspiron Mini 10 Palm Rest Bracket Replacement, Palm Rest Bracket: 7 단계, 이미지 1개 중 1개
    • Close the device and turn over.
    • Remove the five 8mm Phillips 0 screws.
  8. Dell Inspiron Mini 10 Palm Rest Bracket Replacement: 8 단계, 이미지 2개 중 1개 Dell Inspiron Mini 10 Palm Rest Bracket Replacement: 8 단계, 이미지 2개 중 2개
    • Turn the device over and open the display.
    • Remove the single 8mm Phillips 0 screw attaching the hard-drive cage to the body of the device.
  9. Dell Inspiron Mini 10 Palm Rest Bracket Replacement: 9 단계, 이미지 2개 중 1개 Dell Inspiron Mini 10 Palm Rest Bracket Replacement: 9 단계, 이미지 2개 중 2개
    • Pull on the black tab and slide the hard-drive cage toward the USB port on the left side of the device until its comes free and carefully lift out of device.
  10. Dell Inspiron Mini 10 Palm Rest Bracket Replacement: 10 단계, 이미지 2개 중 1개 Dell Inspiron Mini 10 Palm Rest Bracket Replacement: 10 단계, 이미지 2개 중 2개
    • Remove the four 6mm Philips 0 screws securing the bracket.
  11. Dell Inspiron Mini 10 Palm Rest Bracket Replacement: 11 단계, 이미지 3개 중 1개 Dell Inspiron Mini 10 Palm Rest Bracket Replacement: 11 단계, 이미지 3개 중 2개 Dell Inspiron Mini 10 Palm Rest Bracket Replacement: 11 단계, 이미지 3개 중 3개
    • Disconnect the following:
    • Power button cable
    • Speaker cable
    • Power status light cable
    • Bluetooth cable (if installed)
  12. Dell Inspiron Mini 10 Palm Rest Bracket Replacement: 12 단계, 이미지 1개 중 1개
    • Gently pry off the bracket using the prying tool.
결론
작성자
4다른 기여자 명과 함께
Danielle Jarecki
회원 가입일: 10/21/16
334 평판
안내서 5개를 작성함
UW Tacoma, Team 1-4, Rose Fall 2016 UW Tacoma, Team 1-4, Rose Fall 2016 회원
UWT-ROSE-F16S1G4
4 회원들
안내서 10개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 0
지난 30일: 8
전체 시간: 369
