주요 콘텐츠로 건너뛰기
Dell Inspiron Mini 10 Touchpad Replacement
필요한 것
  1. Dell Inspiron Mini 10 Touchpad Replacement, Battery: 1 단계, 이미지 1/1
    • To prevent injury and loss of data, ensure the device is turned off.
    • Slide the release latches out toward the edges to unlock the battery.
  2. Dell Inspiron Mini 10 Touchpad Replacement: 2 단계, 이미지 1/1
    • Remove the battery by pulling it up and out.
  3. Dell Inspiron Mini 10 Touchpad Replacement, Touchpad: 3 단계, 이미지 1/2 Dell Inspiron Mini 10 Touchpad Replacement, Touchpad: 3 단계, 이미지 2/2
    • Using a spudger, gently pry the palm rest off of the palm rest bracket.
    • Carefully remove the palm rest from the computer base to avoid damage to the palm rest.
  4. Dell Inspiron Mini 10 Touchpad Replacement: 4 단계, 이미지 1/1
    • Gently pull the touchpad cable off the palm rest bracket.
    • Lift the rest of the palm rest off the computer base.
  5. Dell Inspiron Mini 10 Touchpad Replacement: 5 단계, 이미지 1/3 Dell Inspiron Mini 10 Touchpad Replacement: 5 단계, 이미지 2/3 Dell Inspiron Mini 10 Touchpad Replacement: 5 단계, 이미지 3/3
    • Turn the palm rest assembly over.
    • Remove the four 3mm Phillips 0 screws that secure the touchpad module to the palm rest.
    • Gently lift the copper and silver foil squares on the touchpad.
    • Remove the touchpad from the palm rest.
결론
Angela Wild
회원 가입일: 10/26/16
104 평판
안내서 1개 작성함
UW Tacoma, Team 1-4, Rose Fall 2016 UW Tacoma, Team 1-4, Rose Fall 2016 회원
UWT-ROSE-F16S1G4
4 회원들
안내서 10개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 1
전체 시간: 592
