주요 콘텐츠로 건너뛰기
Dell Inspiron Mini 1018 WiFi Adapter Replacement
필요한 것
  1. Dell Inspiron Mini 1018 WiFi Adapter Replacement, Battery: 1 단계, 이미지 1/1
    • To prevent injury and loss of data, ensure the device is turned off.
    • Slide the release latches out toward the edges to unlock the battery.
  2. Dell Inspiron Mini 1018 WiFi Adapter Replacement: 2 단계, 이미지 1/1
    • Remove the battery by pulling it up and out.
  3. Dell Inspiron Mini 1018 WiFi Adapter Replacement, WiFi Adapter: 3 단계, 이미지 1/2 Dell Inspiron Mini 1018 WiFi Adapter Replacement, WiFi Adapter: 3 단계, 이미지 2/2
    • On the bottom of the laptop locate the removable panel and screw holding it to the body. Loosen the screw and take the cover off.
  4. Dell Inspiron Mini 1018 WiFi Adapter Replacement: 4 단계, 이미지 1/2 Dell Inspiron Mini 1018 WiFi Adapter Replacement: 4 단계, 이미지 2/2
    이 단계에 사용된 도구:
    구매
    • Remove the black and white antenna cable from the wifi adapter by pinching the gold contacts with the tips of your finger, or you can use tweezers, and pull them straight away from the adapter.
    • Unscrew the single 5mm Phillips 0 screw on the top right of the adapter. The adapter should start to angle away from the body of the computer. Once the screw is off completely, pull the adapter out of the data slot.
결론
Bariso Shuba
회원 가입일: 10/26/16
270 평판
안내서 3개 작성하였습니다
UW Tacoma, Team 1-4, Rose Fall 2016 UW Tacoma, Team 1-4, Rose Fall 2016 회원
UWT-ROSE-F16S1G4
4 회원들
안내서 10개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 4
전체 시간: 988
