주요 콘텐츠로 건너뛰기
Dell Inspiron Mini 1012 Battery Replacement
  1. Dell Inspiron Mini 1012 Battery Replacement, Battery: 1 단계, 이미지 3개 중 1개 Dell Inspiron Mini 1012 Battery Replacement, Battery: 1 단계, 이미지 3개 중 2개 Dell Inspiron Mini 1012 Battery Replacement, Battery: 1 단계, 이미지 3개 중 3개
    • Turn the device over so the bottom is facing upwards.
    • Slide the two tabs beside the lock icons to the unlocked position.
    • Find the notch located in the center between the two tabs and lift up on the battery to remove it.
    • To replace the battery, align the three notches on the battery with the grooves on the device. Snap the battery back onto the device, and it will lock in place.
결론
To reassemble, place the new battery in the three slots. Lock the battery back in place.
작성자
6다른 기여자 명과 함께
sabinabarajas
회원 가입일: 10/17/15
387 평판
안내서 3개를 작성함
Gateway, Team 2-2, Kuhn Fall 2015 Gateway, Team 2-2, Kuhn Fall 2015 회원
GCC-KUHN-F15S2G2
1 회원
안내서 6개를 작성함
1가이드 댓글
So, I’ve installed the new battery and the mini 1012 won’t recognize or charge it. Now what?
complainingparty - 답글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 2
지난 30일: 21
전체 시간: 1,776
