주요 콘텐츠로 건너뛰기
Dell Inspiron Mini 1012 Keyboard Replacement
필요한 것
  1. Dell Inspiron Mini 1012 Keyboard Replacement, Keyboard: 1 단계, 이미지 1/3 Dell Inspiron Mini 1012 Keyboard Replacement, Keyboard: 1 단계, 이미지 2/3 Dell Inspiron Mini 1012 Keyboard Replacement, Keyboard: 1 단계, 이미지 3/3
    • Unlock the two tabs on the bottom of the laptop.
    • Use your fingernail or a spudger to pull the battery pack out of the laptop.
  2. Dell Inspiron Mini 1012 Keyboard Replacement: 2 단계, 이미지 1/1
    • Remove the three screws with a Phillips #00 screwdriver.
  3. Dell Inspiron Mini 1012 Keyboard Replacement: 3 단계, 이미지 1/2 Dell Inspiron Mini 1012 Keyboard Replacement: 3 단계, 이미지 2/2
    • Insert the spudger between the top of the keyboard and the laptop body.
    • Carefully pry the keyboard up.
    • Be gentle! You don't want to damage the laptops ribbon cable connector by pulling too hard.
    • It's not recommended to use a metal spudger for this repair as the photo shows. A regular nylon spudger will work just fine.
  4. Dell Inspiron Mini 1012 Keyboard Replacement: 4 단계, 이미지 1/2 Dell Inspiron Mini 1012 Keyboard Replacement: 4 단계, 이미지 2/2
    • Unlock the connector to release the ribbon cable.
    • Carefully pull on the clear tab to remove the keyboard from the device.
  5. Dell Inspiron Mini 1012 Keyboard Replacement: 5 단계, 이미지 1/3 Dell Inspiron Mini 1012 Keyboard Replacement: 5 단계, 이미지 2/3 Dell Inspiron Mini 1012 Keyboard Replacement: 5 단계, 이미지 3/3
    • Take the new keyboard and insert the ribbon cable into the connector on the laptop.
    • Lay the keyboard back onto the device and gently snap it back into place.
결론
To reassemble your device, follow these instructions in reverse order starting at step two.
sabinabarajas
회원 가입일: 10/17/15
372 평판
안내서 3개 작성하였습니다
Gateway, Team 2-2, Kuhn Fall 2015 Gateway, Team 2-2, Kuhn Fall 2015 회원
GCC-KUHN-F15S2G2
1 회원
안내서 6개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 4
30일 전: 14
전체 시간: 659
