소개
Use this guide to replace the keyboard on your Dell Inspiron Mini 1012 laptop.
The keyboard is used to directly put information into your laptop, meaning a broken or non-working keyboard can render a laptop unusable. When a keyboard is failing, it's common to see keys that aren't working, repeating itself, or coming out with a different output.
필요한 것
Unlock the two tabs on the bottom of the laptop.
Use your fingernail or a spudger to pull the battery pack out of the laptop.
거의 끝나갑니다!
To reassemble your device, follow these instructions in reverse order starting at step two.
결론
