주요 콘텐츠로 건너뛰기
Dell Inspiron Mini 1012: Keyboard Replacement
필요한 것
  1. Dell Inspiron Mini 1012: Keyboard Replacement, Keyboard: 1 단계, 이미지 1/1
    • Remove the battery
  2. Dell Inspiron Mini 1012: Keyboard Replacement: 2 단계, 이미지 1/1
    • Using a Philip's head screwdriver, remove three screws: one directly below the battery and the other two to the right and the left of the two battery lock switches
  3. Dell Inspiron Mini 1012: Keyboard Replacement: 3 단계, 이미지 1/2 Dell Inspiron Mini 1012: Keyboard Replacement: 3 단계, 이미지 2/2
    • At the top of the keyboard, insert the metal spudger between the keyboard's metal frame and the body of the laptop as shown
    • When inserting the metal spudger, be sure to place the spudger under the frame and not under a key to avoid damaging the component
    • Gently lift up the keyboard starting at the top of the frame
    • Make sure that you do not damage the ribbon attached to the bottom of the keyboard
  4. Dell Inspiron Mini 1012: Keyboard Replacement: 4 단계, 이미지 1/1
    • Pull the clear tab at the end of the ribbon towards the hard drive to detach the ribbon
    • Perform steps one through four in reverse order with your new keyboard to finish the replacement process
결승점
다른 4명이 해당 안내서를 완성하였습니다.
Marie K Bordley
회원 가입일: 09/30/14
241 평판
안내서 2개 작성하였습니다
Ohio State, Team 1-1, Buehl Fall 2014 Ohio State, Team 1-1, Buehl Fall 2014 회원
OSU-BUEHL-F14S1G1
4 회원들
안내서 4개 작성하였습니다
댓글 한 개
After keyboard open, You can change HDD or Memory as you like.
최희욱 - 답글
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 1
30일 전: 14
전체 시간: 3,295
