주요 콘텐츠로 건너뛰기
Dell Inspiron N4010 Screen Replacement
필요한 것
  1. Dell Inspiron N4010 Screen Replacement, Screen: 1 단계, 이미지 1/3 Dell Inspiron N4010 Screen Replacement, Screen: 1 단계, 이미지 2/3 Dell Inspiron N4010 Screen Replacement, Screen: 1 단계, 이미지 3/3
    • Use a plastic opening tool to remove the screen bezel.
  2. Dell Inspiron N4010 Screen Replacement: 2 단계, 이미지 1/3 Dell Inspiron N4010 Screen Replacement: 2 단계, 이미지 2/3 Dell Inspiron N4010 Screen Replacement: 2 단계, 이미지 3/3
    • Using the #0 Philips head, unscrew the screen bracket from the base of the laptop.
  3. Dell Inspiron N4010 Screen Replacement: 3 단계, 이미지 1/3 Dell Inspiron N4010 Screen Replacement: 3 단계, 이미지 2/3 Dell Inspiron N4010 Screen Replacement: 3 단계, 이미지 3/3
    • Remove the plastic seal located on the back of the screen to expose the ribbon connector.
    • Unplug the ribbon cable from the screen.
    • Be careful when unplugging the cable. Make sure you peel the tape all the way back before disconnecting.
  4. Dell Inspiron N4010 Screen Replacement: 4 단계, 이미지 1/3 Dell Inspiron N4010 Screen Replacement: 4 단계, 이미지 2/3 Dell Inspiron N4010 Screen Replacement: 4 단계, 이미지 3/3
    • Use the #0 Philips head to remove the six screws on either sides of the screen frame.
    • Remove the metal frame from the screen.
결론
다른 2명이 해당 안내서를 완성하였습니다.
Jonathan Sellier
회원 가입일: 09/26/17
952 평판
안내서 7개 작성하였습니다
USF Tampa, Team S13-G5, Boczar Fall 2017 USF Tampa, Team S13-G5, Boczar Fall 2017 회원
USFT-BOCZAR-F17S13G5
5 회원들
안내서 9개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 1
30일 전: 19
전체 시간: 1,431
