주요 콘텐츠로 건너뛰기
Dell Inspiron N4010 Top Cover Replacement
필요한 것
  1. Dell Inspiron N4010 Top Cover Replacement, Battery: 1 단계, 이미지 1/1
    • Make sure the laptop is not plugged into any wall outlets or the charger
    • Unlock the battery by sliding the right-hand switch to the right.
  2. Dell Inspiron N4010 Top Cover Replacement: 2 단계, 이미지 1/2 Dell Inspiron N4010 Top Cover Replacement: 2 단계, 이미지 2/2
    • While holding the left-hand switch to the left position, pull the battery away from the laptop.
  3. Dell Inspiron N4010 Top Cover Replacement: 3 단계, 이미지 1/1
    • The battery is now fully removed and the laptop will not power on without it.
  4. Dell Inspiron N4010 Top Cover Replacement, Keyboard: 4 단계, 이미지 1/3 Dell Inspiron N4010 Top Cover Replacement, Keyboard: 4 단계, 이미지 2/3 Dell Inspiron N4010 Top Cover Replacement, Keyboard: 4 단계, 이미지 3/3
    • Using the #0 Philips head, unscrew the indicated screw.
    • Carefully pull the RAM cover up and away.
  5. Dell Inspiron N4010 Top Cover Replacement: 5 단계, 이미지 1/1
    • Unscrew the indicated 5.7mm screw beneath the RAM Cover.
    • Remove another screw above the battery release tab
  6. Dell Inspiron N4010 Top Cover Replacement: 7 단계, 이미지 1/2 Dell Inspiron N4010 Top Cover Replacement: 7 단계, 이미지 2/2
    • Using a thin plastic tool (such as a guitar pick or spudger) at the top of the keyboard just above the F7 key, gently pry the keyboard away.
    • Move the spudger to either end at the top of the keyboard to fully undo all plastic clips.
  7. Dell Inspiron N4010 Top Cover Replacement: 8 단계, 이미지 1/2 Dell Inspiron N4010 Top Cover Replacement: 8 단계, 이미지 2/2
    • Carefully tip the keyboard upwards and pull it slightly away from the body of the laptop.
    • Be careful not to put stress on the ribbon cable below.
  8. Dell Inspiron N4010 Top Cover Replacement: 9 단계, 이미지 1/2 Dell Inspiron N4010 Top Cover Replacement: 9 단계, 이미지 2/2
    • Carefully unclip the ribbon cable by tipping the keyboard towards the screen.
    • The keyboard is now completely disconnected.
  9. Dell Inspiron N4010 Top Cover Replacement, Top Cover: 10 단계, 이미지 1/2 Dell Inspiron N4010 Top Cover Replacement, Top Cover: 10 단계, 이미지 2/2
    • Remove the indicated 5.7mm screws.
    • Remove the smaller 3mm screws from underneath the battery compartment.
  10. Dell Inspiron N4010 Top Cover Replacement: 11 단계, 이미지 1/2 Dell Inspiron N4010 Top Cover Replacement: 11 단계, 이미지 2/2
    • With a plastic spudger, pry away the silver top cover from the black casing.
    • Move the tool to the right and left along the seams to fully disconnect the cover.
  11. Dell Inspiron N4010 Top Cover Replacement: 12 단계, 이미지 1/1
    • Disconnect the indicated ribbon cables underneath where the keyboard sits.
  12. Dell Inspiron N4010 Top Cover Replacement: 13 단계, 이미지 1/1
    • Lift the cover upwards and away from the body of the laptop, after removing the optical drive and unscrewing the three screws on the right
결론
Jonathan Sellier
회원 가입일: 09/26/17
952 평판
안내서 7개 작성하였습니다
USF Tampa, Team S13-G5, Boczar Fall 2017 USF Tampa, Team S13-G5, Boczar Fall 2017 회원
USFT-BOCZAR-F17S13G5
5 회원들
안내서 9개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 7
30일 전: 11
전체 시간: 713
