주요 콘텐츠로 건너뛰기
Dell Inspiron N4110 RAM Replacement
필요한 것
  1. Dell Inspiron N4110 RAM Replacement, Battery: 1 단계, 이미지 1/1
    • Make sure the laptop is off and unplugged before starting this step.
    • Locate the battery on the underside of the laptop.
    • Push the two battery clips following the direction of the arrows.
  2. Dell Inspiron N4110 RAM Replacement: 2 단계, 이미지 1/1
    • Push upward from the base of the battery.
  3. Dell Inspiron N4110 RAM Replacement: 3 단계, 이미지 1/1
    • Pull battery away from computer until it is fully removed.
  4. Dell Inspiron N4110 RAM Replacement, RAM: 4 단계, 이미지 1/2 Dell Inspiron N4110 RAM Replacement, RAM: 4 단계, 이미지 2/2
    • Locate and unscrew the one 2.5x5 mm screw on the cover.
    • The screw does not detach from the cover. Make sure the screw is fully unscrewed before attempting to remove the cover.
  5. Dell Inspiron N4110 RAM Replacement: 5 단계, 이미지 1/2 Dell Inspiron N4110 RAM Replacement: 5 단계, 이미지 2/2
    • Remove RAM cover from the laptop.
  6. Dell Inspiron N4110 RAM Replacement: 6 단계, 이미지 1/2 Dell Inspiron N4110 RAM Replacement: 6 단계, 이미지 2/2
    • Use your fingers to separate the two metal clips from the RAM.
    • The RAM will lift up when properly separated. Do not force the RAM out of the clips.
  7. Dell Inspiron N4110 RAM Replacement: 7 단계, 이미지 1/1
    • Remove the RAM from the computer.
    • Be careful as to not touch the metal on the bottom of the RAM. This can cause damage.
    • The RAM should be placed on a non-conductive surface.
결론
다른 2명이 해당 안내서를 완성하였습니다.
Olivia
회원 가입일: 03/20/18
773 평판
안내서 3개 작성하였습니다
UMass Dartmouth, Team S5-G1, Peak Spring 2018 UMass Dartmouth, Team S5-G1, Peak Spring 2018 회원
UMASSD-PEAK-S18S5G1
3 회원들
안내서 6개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 3
30일 전: 15
전체 시간: 767
