주요 콘텐츠로 건너뛰기
Dell Inspiron N4110 Screen Replacement
필요한 것
  1. Dell Inspiron N4110 Screen Replacement, Battery: 1 단계, 이미지 1/1
    • Make sure the laptop is off and unplugged before starting this step.
    • Locate the battery on the underside of the laptop.
    • Push the two battery clips following the direction of the arrows.
  2. Dell Inspiron N4110 Screen Replacement: 2 단계, 이미지 1/1
    • Push upward from the base of the battery.
  3. Dell Inspiron N4110 Screen Replacement: 3 단계, 이미지 1/1
    • Pull battery away from computer until it is fully removed.
  4. Dell Inspiron N4110 Screen Replacement, Screen: 4 단계, 이미지 1/3 Dell Inspiron N4110 Screen Replacement, Screen: 4 단계, 이미지 2/3 Dell Inspiron N4110 Screen Replacement, Screen: 4 단계, 이미지 3/3
    • Use your hands to remove the plastic cover from around the screen.
    • This can seem difficult, but it can be done.
  5. Dell Inspiron N4110 Screen Replacement: 5 단계, 이미지 1/2 Dell Inspiron N4110 Screen Replacement: 5 단계, 이미지 2/2
    • Unscrew the two 2.5x4 mm screws from the top of the screen.
  6. Dell Inspiron N4110 Screen Replacement: 6 단계, 이미지 1/2 Dell Inspiron N4110 Screen Replacement: 6 단계, 이미지 2/2
    • Loosen the four 2.5x4 mm screws from the base of the screen.
    • This will allow the screen to lift from inside the top of the case.
  7. Dell Inspiron N4110 Screen Replacement: 7 단계, 이미지 1/3 Dell Inspiron N4110 Screen Replacement: 7 단계, 이미지 2/3 Dell Inspiron N4110 Screen Replacement: 7 단계, 이미지 3/3
    • Unscrew the four 2x3 mm screws from the two sides on both the top and bottom.
  8. Dell Inspiron N4110 Screen Replacement: 8 단계, 이미지 1/2 Dell Inspiron N4110 Screen Replacement: 8 단계, 이미지 2/2
    이 단계에 사용된 도구:
    구매
    • Use tweezers to peel the webcam away from the top of the laptop.
    • The webcam is only held in place by a webcam, this is easy to pull away from the screen.
  9. Dell Inspiron N4110 Screen Replacement: 9 단계, 이미지 1/3 Dell Inspiron N4110 Screen Replacement: 9 단계, 이미지 2/3 Dell Inspiron N4110 Screen Replacement: 9 단계, 이미지 3/3
    • Lift the adhesive flap from the cord that connects the computer to the screen.
    • You can then disconnect the cord from the screen.
  10. Dell Inspiron N4110 Screen Replacement: 10 단계, 이미지 1/1
    • The screen can now be fully removed from the computer.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
Abigail Keith
회원 가입일: 03/20/18
505 평판
안내서 2개 작성하였습니다
UMass Dartmouth, Team S5-G1, Peak Spring 2018 UMass Dartmouth, Team S5-G1, Peak Spring 2018 회원
UMASSD-PEAK-S18S5G1
3 회원들
안내서 6개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 3
30일 전: 17
전체 시간: 1,248
