주요 콘텐츠로 건너뛰기
Dell Inspiron N5010 Display Assembly Replacement
필요한 것
  1. Dell Inspiron N5010 Display Assembly Replacement, Remove the Screws: 1 단계, 이미지 1개 중 1개
    • WARNING: Before working inside your computer, read the safety information that shipped with your computer. Follow the instructions in Before You Begin.
    • CAUTION: To avoid electrostatic discharge, ground yourself by using a wrist grounding strap or by periodically touching an unpainted metal surface (such as a connector on your computer).
    • Turn the computer over and remove the two screws.
  2. Dell Inspiron N5010 Display Assembly Replacement, Disconnect the Antenna Cables: 2 단계, 이미지 1개 중 1개
    • Disconnect the Mini-Card antenna cables from the Mini-Card.
  3. Dell Inspiron N5010 Display Assembly Replacement, Disconnect the Display Cable: 3 단계, 이미지 1개 중 1개
    • Disconnect the display cable from the connector on the system board and remove it from the routing guide.
  4. Dell Inspiron N5010 Display Assembly Replacement, Remove the Screws: 4 단계, 이미지 1개 중 1개
    • Remove the four screws (two on each side) that secure the display assembly to the computer base.
  5. Dell Inspiron N5010 Display Assembly Replacement, Removing the Display Assembly: 5 단계, 이미지 1개 중 1개
    • Lift and remove the display assembly out of the computer base.
  6. Dell Inspiron N5010 Display Assembly Replacement, Placing the Display Assembly: 6 단계, 이미지 1개 중 1개
    • Place the NEW display assembly in position and replace the four screws (two on each side) that secure the display assembly to the computer base.
  7. Dell Inspiron N5010 Display Assembly Replacement, Routing the Display Cable: 7 단계, 이미지 1개 중 1개
    • Route the display cable into the routing guide and connect the cable to the connector on the system board.
  8. Dell Inspiron N5010 Display Assembly Replacement, Connect the Antenna Cables: 8 단계, 이미지 1개 중 1개
    • Connect the Mini-Card antenna cables to the connectors on the Mini- Card.
  9. Dell Inspiron N5010 Display Assembly Replacement, Replace the Screws: 9 단계, 이미지 1개 중 1개
    • Turn the computer over and replace the two screws at the bottom of the computer.
결승점
다른 한 분이 해당 안내서를 완성하였습니다.
작성자
2다른 기여자 명과 함께
Terrence15
회원 가입일: 12/18/17
79,831 평판
안내서 441개를 작성함
RampUP America, Inc. RampUP America, Inc. 회원
Community
43 회원들
안내서 1,991개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 2
지난 30일: 22
전체 시간: 1,778
