주요 콘텐츠로 건너뛰기
Dell Inspiron N5010 Hard Drive Replacement
필요한 것
    • WARNING: Before working inside your computer, read the safety information that shipped with your computer. Follow the instructions in Before You Begin.
    • CAUTION: To avoid electrostatic discharge, ground yourself by using a wrist grounding strap or by periodically touching an unpainted metal surface (such as a connector on your computer).
    • CAUTION: Hard drives are extremely fragile. Exercise care when handling the hard drive.
  1. Dell Inspiron N5010 Hard Drive Replacement, Remove the Screws: 2 단계, 이미지 1개 중 1개
    • Remove the four screws that secure the hard-drive assembly.
  2. Dell Inspiron N5010 Hard Drive Replacement, Lifting the Hard Drive Assembly: 3 단계, 이미지 1개 중 1개
    • Turn the computer over and lift the hard-drive assembly out of the hard-drive bay to disconnect the hard-drive assembly from the connector on the system board.
  3. Dell Inspiron N5010 Hard Drive Replacement, Disconnect the Interposer: 4 단계, 이미지 1개 중 1개
    • Pull the interposer to disconnect it from the hard drive.
  4. Dell Inspiron N5010 Hard Drive Replacement, Connect the Interposer: 5 단계, 이미지 1개 중 1개
    • Connect the interposer to the NEW hard drive.
  5. Dell Inspiron N5010 Hard Drive Replacement, Align the Hard Drive Assembly: 6 단계, 이미지 1개 중 1개
    • Align the hard-drive assembly with the connector on the system board and press the hard-drive assembly into the hard-drive bay until it is fully seated.
  6. Dell Inspiron N5010 Hard Drive Replacement, Replace the Screws: 7 단계, 이미지 1개 중 1개
    • Turn the computer over and replace the four screws that secure the hard-drive assembly.
결승점
다른 2명이 해당 안내서를 완성하였습니다.
작성자
3다른 기여자 명과 함께
Terrence15
회원 가입일: 12/18/17
79,831 평판
안내서 441개를 작성함
RampUP America, Inc. RampUP America, Inc. 회원
Community
43 회원들
안내서 1,991개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 2
지난 30일: 17
전체 시간: 2,270
