주요 콘텐츠로 건너뛰기
Dell Inspiron N5030 Keyboard Replacement
필요한 것
  1. Dell Inspiron N5030 Keyboard Replacement, Battery: 1 단계, 이미지 1/2 Dell Inspiron N5030 Keyboard Replacement, Battery: 1 단계, 이미지 2/2
    • Turn the computer over on its back so the battery compartment faces towards you.
    • Place your fingers on the small buttons with arrows pointing outwards.
    • Push and slide the buttons outward to unlock the battery compartment.
  2. Dell Inspiron N5030 Keyboard Replacement: 2 단계, 이미지 1/2 Dell Inspiron N5030 Keyboard Replacement: 2 단계, 이미지 2/2
    • Grab the battery and pull it towards yourself.
    • Remove the battery.
  3. Dell Inspiron N5030 Keyboard Replacement, Keyboard: 3 단계, 이미지 1/1
    • Use a Phillips #0 screwdriver to unscrew the sixteen 0.6 mm screws on the back panel.
  4. Dell Inspiron N5030 Keyboard Replacement: 4 단계, 이미지 1/1
    • Flip over the laptop and open it so that the screen faces you.
  5. Dell Inspiron N5030 Keyboard Replacement: 5 단계, 이미지 1/1
    • Use the plastic opening tool and your fingers to pry off the top panel.
    • Pry the panel off starting at any one of the corners and then continue around the edges of the computer.
  6. Dell Inspiron N5030 Keyboard Replacement: 6 단계, 이미지 1/1
    • Be careful when lifting off the keyboard panel. There are multiple delicate cables connecting the panel to the motherboard.
    • Pull up on the blue plastic tab connected by the white strip to unhook the keyboard panel from the motherboard.
  7. Dell Inspiron N5030 Keyboard Replacement: 7 단계, 이미지 1/1
    • Flip up the small locking flap on the keyboard cable ZIF socket and disconnect the keyboard ribbon cable.
  8. Dell Inspiron N5030 Keyboard Replacement: 8 단계, 이미지 1/1
    • Pull up on the wire tab with the blue, white, black, and red wires to detach the speakers from the motherboard.
  9. Dell Inspiron N5030 Keyboard Replacement: 9 단계, 이미지 1/1
    • Remove the top keyboard panel.
결론
다른 5명이 해당 안내서를 완성하였습니다.
Gunnar Salazar
회원 가입일: 09/30/13
128 평판
안내서 1개 작성함
Cal Poly, Team 10-59, Amido Spring 2014 Cal Poly, Team 10-59, Amido Spring 2014 회원
CPSU-AMIDO-S14S10G59
4 회원들
안내서 5개 작성하였습니다
댓글 2개
What if i broke the blue ribbons connection to the keyboard
oibrahimopeyemi - 답글
This solution is quite troublesome and does not explain how to disconnect / re-connect the wide flat keyboard cable. For a simpler solution see :
https://www.youtube.com/watch?v=jWuGb9AA...
Agropecuaria El Sinu - 답글
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 2
30일 전: 13
전체 시간: 2,799
