주요 콘텐츠로 건너뛰기
Dell Inspiron N5050 Hard Drive Replacement
필요한 것
  1. Dell Inspiron N5050 Hard Drive Replacement, Battery: 1 단계, 이미지 1/1
    • Flip your laptop over to view the bottom and the two locks.
  2. Dell Inspiron N5050 Hard Drive Replacement: 2 단계, 이미지 1/1
    • Slide the two locks away from each other.
    • Sliding these locks will loosen the battery to allow removal.
  3. Dell Inspiron N5050 Hard Drive Replacement: 3 단계, 이미지 1/2 Dell Inspiron N5050 Hard Drive Replacement: 3 단계, 이미지 2/2
    • Pull the battery out of the laptop.
    • Your laptop's battery should be completely removed.
  4. Dell Inspiron N5050 Hard Drive Replacement, Hard Drive: 4 단계, 이미지 1/1
    • Remove the eleven 5mm palmrest screws from the bottom of the laptop with a Phillips #PH00 screw.
    • Remove the two 3mm hard drive screws from the bottom of the laptop with a Phillips #PH00 screw.
  5. Dell Inspiron N5050 Hard Drive Replacement: 5 단계, 이미지 1/2 Dell Inspiron N5050 Hard Drive Replacement: 5 단계, 이미지 2/2
    • Flip over and open the laptop to view the keyboard.
    • Use a plastic opening tool to press down on four clips, one by one.
    • Press down on the clips and pull the tool towards you to pry the keyboard loose.
    • The four clips are above the Esc, F6, F11, and Delete keys.
  6. Dell Inspiron N5050 Hard Drive Replacement: 6 단계, 이미지 1/3 Dell Inspiron N5050 Hard Drive Replacement: 6 단계, 이미지 2/3 Dell Inspiron N5050 Hard Drive Replacement: 6 단계, 이미지 3/3
    • Remove the keyboard carefully.
    • Make sure to lift the keyboard gently, because a cable is connected to the back.
    • Flip the keyboard over to find the keyboard cable.
    • Pull the cable labeled "UP" out to disconnect it from the laptop.
  7. Dell Inspiron N5050 Hard Drive Replacement: 7 단계, 이미지 1/3 Dell Inspiron N5050 Hard Drive Replacement: 7 단계, 이미지 2/3 Dell Inspiron N5050 Hard Drive Replacement: 7 단계, 이미지 3/3
    • Unscrew the two palmrest screws.
    • Lift the two, blue palmrest cables up and out of their sockets.
  8. Dell Inspiron N5050 Hard Drive Replacement: 8 단계, 이미지 1/2 Dell Inspiron N5050 Hard Drive Replacement: 8 단계, 이미지 2/2
    • Lift the entire surface (palmrest casing) to expose the motherboard underneath.
  9. Dell Inspiron N5050 Hard Drive Replacement: 9 단계, 이미지 1/1
    • Slide the hard drive right and up to remove it from the laptop.
결론
다른 11명이 해당 안내서를 완성하였습니다.
Kristy Mayo
회원 가입일: 09/15/16
1,394 평판
안내서 3개 작성하였습니다
University of North Texas, Team 1-3, Campbell Fall 2016 University of North Texas, Team 1-3, Campbell Fall 2016 회원
UNT-CAMPBELL-F16S1G3
2 회원들
안내서 3개 작성하였습니다
댓글 4개
Thanks again. This guide was made straightforward and clear.
jason acn - 답글
Thanks you - The clear instructions make this guide easy to follow.
Jay - 답글
wouldnt turn on after i re-assembled it
Taemon Coolz - 답글
Sehr gute Arbeit
pouchman - 답글
댓글 쓰기
조회 통계:
24 시간 전: 4
7일 전: 9
30일 전: 51
전체 시간: 6,773
