주요 콘텐츠로 건너뛰기
Dell Inspiron N5050 RAM Replacement
필요한 것
  1. Dell Inspiron N5050 RAM Replacement, Battery: 1 단계, 이미지 1/1
    • Flip your laptop over to view the bottom and the two locks.
    How many gb hard drive can I install on Inspiron n5050
    Anguiano pro - 답글
  2. Dell Inspiron N5050 RAM Replacement: 2 단계, 이미지 1/1
    • Slide the two locks away from each other.
    • Sliding these locks will loosen the battery to allow removal.
  3. Dell Inspiron N5050 RAM Replacement: 3 단계, 이미지 1/2 Dell Inspiron N5050 RAM Replacement: 3 단계, 이미지 2/2
    • Pull the battery out of the laptop.
    • Your laptop's battery should be completely removed.
  4. Dell Inspiron N5050 RAM Replacement, RAM: 4 단계, 이미지 1/1
    • Remove the eleven 5mm palmrest screws from the bottom of the laptop with a Phillips #PH00 screw.
    • Remove the two 3mm hard drive screws from the bottom of the laptop with a Phillips #PH00 screw.
  5. Dell Inspiron N5050 RAM Replacement: 5 단계, 이미지 1/2 Dell Inspiron N5050 RAM Replacement: 5 단계, 이미지 2/2
    • Flip over and open the laptop to view the keyboard.
    • Use a plastic opening tool to press down on four clips, one by one.
    • Press down on the clips and pull the tool towards you to pry the keyboard loose.
    • The four clips are above the Esc, F6, F11, and Delete keys.
  6. Dell Inspiron N5050 RAM Replacement: 6 단계, 이미지 1/3 Dell Inspiron N5050 RAM Replacement: 6 단계, 이미지 2/3 Dell Inspiron N5050 RAM Replacement: 6 단계, 이미지 3/3
    • Remove the keyboard carefully.
    • Make sure to lift the keyboard gently, because a cable is connected to the back.
    • Flip the keyboard over to find the keyboard cable.
    • Pull the cable labeled "UP" out to disconnect it from the laptop.
  7. Dell Inspiron N5050 RAM Replacement: 7 단계, 이미지 1/3 Dell Inspiron N5050 RAM Replacement: 7 단계, 이미지 2/3 Dell Inspiron N5050 RAM Replacement: 7 단계, 이미지 3/3
    • Find the RAM and pull apart the two clips.
    • After pulling apart both clips, the RAM component will snap up.
  8. Dell Inspiron N5050 RAM Replacement: 8 단계, 이미지 1/2 Dell Inspiron N5050 RAM Replacement: 8 단계, 이미지 2/2
    • Remove the RAM.
결론
다른 7명이 해당 안내서를 완성하였습니다.
Kristy Mayo
회원 가입일: 09/15/16
1,394 평판
안내서 3개 작성하였습니다
University of North Texas, Team 1-3, Campbell Fall 2016 University of North Texas, Team 1-3, Campbell Fall 2016 회원
UNT-CAMPBELL-F16S1G3
2 회원들
안내서 3개 작성하였습니다
댓글 한 개
Thanks Kristy,
I was breath new life back into an old laptop and re-purpose after upgrading the RAM.
jason acn - 답글
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 4
30일 전: 14
전체 시간: 2,330
