주요 콘텐츠로 건너뛰기
Dell Inspiron One 2020 Hard Drive Replacement
필요한 것
  1. Dell Inspiron One 2020 Hard Drive Replacement, Back Cover: 1 단계, 이미지 1/3 Dell Inspiron One 2020 Hard Drive Replacement, Back Cover: 1 단계, 이미지 2/3 Dell Inspiron One 2020 Hard Drive Replacement, Back Cover: 1 단계, 이미지 3/3
    • Place the all in one computer face down on a soft, clean surface to avoid scratching the front.
    • Press the tab on the stand cover and lift up.
  2. Dell Inspiron One 2020 Hard Drive Replacement: 2 단계, 이미지 1/3 Dell Inspiron One 2020 Hard Drive Replacement: 2 단계, 이미지 2/3 Dell Inspiron One 2020 Hard Drive Replacement: 2 단계, 이미지 3/3
    • Remove the four phillips screws that attach the stand to the computer.
    • Tilt the stand up and out.
  3. Dell Inspiron One 2020 Hard Drive Replacement: 3 단계, 이미지 1/3 Dell Inspiron One 2020 Hard Drive Replacement: 3 단계, 이미지 2/3 Dell Inspiron One 2020 Hard Drive Replacement: 3 단계, 이미지 3/3
    • Starting from the optical drive, pry the back cover up with a plastic spudger.
    • The cover is held in place by fragile plastic clips. Careful to not break them.
  4. Dell Inspiron One 2020 Hard Drive Replacement, Hard Drive: 4 단계, 이미지 1/2 Dell Inspiron One 2020 Hard Drive Replacement, Hard Drive: 4 단계, 이미지 2/2
    • Remove the three screws that hold the hard drive cage to the chassis.
  5. Dell Inspiron One 2020 Hard Drive Replacement: 5 단계, 이미지 1/2 Dell Inspiron One 2020 Hard Drive Replacement: 5 단계, 이미지 2/2
    • Slide the hard drive cage out slightly to access and remove the power and SATA cable.
    • There isn't much slack in these cables, so don't slide the hard drive cage to far.
    • The power and SATA cables are connected together. On most other computers, these connectors are separate.
    • Lift the hard drive cage out.
  6. Dell Inspiron One 2020 Hard Drive Replacement: 6 단계, 이미지 1/3 Dell Inspiron One 2020 Hard Drive Replacement: 6 단계, 이미지 2/3 Dell Inspiron One 2020 Hard Drive Replacement: 6 단계, 이미지 3/3
    • Remove the four screws (two on each side) that attach the hard drive cage to the hard drive.
    • Lift the hard drive cage off the hard drive.
결론
다른 35명이 해당 안내서를 완성하였습니다.
Tyler
회원 가입일: 06/19/12
4,920 평판
안내서 16개 작성하였습니다
TechForce TechForce 회원
Business
2 회원들
안내서 25개 작성하였습니다
댓글 3개
Thanks for this info this is very useful
Thank you once again
Ketan Valsangkar - 답글
Good Job, short and sweet and easy to follow
schmidtrg - 답글
Really useful information thank you.
Jessie Colon - 답글
댓글 쓰기
조회 통계:
24 시간 전: 3
7일 전: 15
30일 전: 82
전체 시간: 35,764
