이 버전에는 잘못된 편집 사항이 있을 수 있습니다. 최신 확인된 스냅샷으로 전환하십시오.
필요한 것
이 단계는 번역되지 않았습니다. 번역을 도와주십시오
Remove the four phillips screws that attach the stand to the computer.
Tilt the stand up and out.
Starting from the optical drive, pry the back cover up with a plastic spudger.
Slide the hard drive cage out slightly to access and remove the power and SATA cable.
Lift the hard drive cage out.
Remove the four screws (two on each side) that attach the hard drive cage to the hard drive.
Lift the hard drive cage off the hard drive.
다른 35명이 해당 안내서를 완성하였습니다.
댓글 3개
Thanks for this info this is very useful
Thank you once again
Really useful information thank you.
