주요 콘텐츠로 건너뛰기
Dell Inspiron i3558-5500BLK Back Cover Replacement
필요한 것
  1. Dell Inspiron i3558-5500BLK Back Cover Replacement, Keyboard: 1 단계, 이미지 2개 중 1개 Dell Inspiron i3558-5500BLK Back Cover Replacement, Keyboard: 1 단계, 이미지 2개 중 2개
    • With the laptop open and facing upright, use the Spudger to pull at the notches shown in the image.
  2. Dell Inspiron i3558-5500BLK Back Cover Replacement: 2 단계, 이미지 3개 중 1개 Dell Inspiron i3558-5500BLK Back Cover Replacement: 2 단계, 이미지 3개 중 2개 Dell Inspiron i3558-5500BLK Back Cover Replacement: 2 단계, 이미지 3개 중 3개
    • Gently turn the keyboard over to reveal the ribbon cable underneath. Remove the cable from the motherboard by lifting the white release tab and gently pulling the cable away from the socket.
    • Lift the keyboard away from the baseboard to remove.
  3. Dell Inspiron i3558-5500BLK Back Cover Replacement, Battery: 3 단계, 이미지 3개 중 1개 Dell Inspiron i3558-5500BLK Back Cover Replacement, Battery: 3 단계, 이미지 3개 중 2개 Dell Inspiron i3558-5500BLK Back Cover Replacement, Battery: 3 단계, 이미지 3개 중 3개
    • With the back of the laptop facing upright, press the switch shown to loosen the battery and remove it.
  4. Dell Inspiron i3558-5500BLK Back Cover Replacement, Back Cover: 4 단계, 이미지 2개 중 1개 Dell Inspiron i3558-5500BLK Back Cover Replacement, Back Cover: 4 단계, 이미지 2개 중 2개
    • With the laptop facing upright - remove the ribbon cable from the optical drive by lifting the white release tab and gently pulling the cable away from the socket.
  5. Dell Inspiron i3558-5500BLK Back Cover Replacement: 5 단계, 이미지 2개 중 1개 Dell Inspiron i3558-5500BLK Back Cover Replacement: 5 단계, 이미지 2개 중 2개
    • Slide the optical drive out of the port on the right-side of the laptop.
  6. Dell Inspiron i3558-5500BLK Back Cover Replacement: 6 단계, 이미지 3개 중 1개 Dell Inspiron i3558-5500BLK Back Cover Replacement: 6 단계, 이미지 3개 중 2개 Dell Inspiron i3558-5500BLK Back Cover Replacement: 6 단계, 이미지 3개 중 3개
    • With the back of the laptop facing upright, remove the following screws:
    • Ten 0.5 mm Phillips screws from the backboard
    • One 0.2 mm Phillips screw from the battery port
    • Three 0.1 mm Phillips screws from the optical drive slot.
  7. Dell Inspiron i3558-5500BLK Back Cover Replacement: 7 단계, 이미지 2개 중 1개 Dell Inspiron i3558-5500BLK Back Cover Replacement: 7 단계, 이미지 2개 중 2개
    • Gently pry the back cover from the opposite side of the battery to reveal the internal components.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
작성자
3다른 기여자 명과 함께
Nathan Ybanez
회원 가입일: 09/27/17
622 평판
안내서 6개를 작성함
Cal Poly, Team S9-G5, Banghart Fall 2017 Cal Poly, Team S9-G5, Banghart Fall 2017 회원
CPSU-BANGHART-F17S9G5
4 회원들
안내서 19개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 1
지난 7일: 7
지난 30일: 27
전체 시간: 1,471
