주요 콘텐츠로 건너뛰기
Dell Inspiron i3558-5500BLK Wireless Card Replacement
필요한 것
  1. Dell Inspiron i3558-5500BLK Wireless Card Replacement, Keyboard: 1 단계, 이미지 1/2 Dell Inspiron i3558-5500BLK Wireless Card Replacement, Keyboard: 1 단계, 이미지 2/2
    • With the laptop open and facing upright, use the Spudger to pull at the notches shown in the image.
  2. Dell Inspiron i3558-5500BLK Wireless Card Replacement: 2 단계, 이미지 1/3 Dell Inspiron i3558-5500BLK Wireless Card Replacement: 2 단계, 이미지 2/3 Dell Inspiron i3558-5500BLK Wireless Card Replacement: 2 단계, 이미지 3/3
    • Gently turn the keyboard over to reveal the ribbon cable underneath. Remove the cable from the motherboard by lifting the white release tab and gently pulling the cable away from the socket.
    • Lift the keyboard away from the baseboard to remove.
  3. Dell Inspiron i3558-5500BLK Wireless Card Replacement, Battery: 3 단계, 이미지 1/3 Dell Inspiron i3558-5500BLK Wireless Card Replacement, Battery: 3 단계, 이미지 2/3 Dell Inspiron i3558-5500BLK Wireless Card Replacement, Battery: 3 단계, 이미지 3/3
    • With the back of the laptop facing upright, press the switch shown to loosen the battery and remove it.
  4. Dell Inspiron i3558-5500BLK Wireless Card Replacement, Back Cover: 4 단계, 이미지 1/2 Dell Inspiron i3558-5500BLK Wireless Card Replacement, Back Cover: 4 단계, 이미지 2/2
    • With the laptop facing upright - remove the ribbon cable from the optical drive by lifting the white release tab and gently pulling the cable away from the socket.
  5. Dell Inspiron i3558-5500BLK Wireless Card Replacement: 5 단계, 이미지 1/2 Dell Inspiron i3558-5500BLK Wireless Card Replacement: 5 단계, 이미지 2/2
    • Slide the optical drive out of the port on the right-side of the laptop.
  6. Dell Inspiron i3558-5500BLK Wireless Card Replacement: 6 단계, 이미지 1/3 Dell Inspiron i3558-5500BLK Wireless Card Replacement: 6 단계, 이미지 2/3 Dell Inspiron i3558-5500BLK Wireless Card Replacement: 6 단계, 이미지 3/3
    • With the back of the laptop facing upright, remove the following screws:
    • Ten 0.5 mm Phillips screws from the backboard
    • One 0.2 mm Phillips screw from the battery port
    • Three 0.1 mm Phillips screws from the optical drive slot.
  7. Dell Inspiron i3558-5500BLK Wireless Card Replacement: 7 단계, 이미지 1/2 Dell Inspiron i3558-5500BLK Wireless Card Replacement: 7 단계, 이미지 2/2
    • Gently pry the back cover from the opposite side of the battery to reveal the internal components.
  8. Dell Inspiron i3558-5500BLK Wireless Card Replacement, Wireless Card: 8 단계, 이미지 1/3 Dell Inspiron i3558-5500BLK Wireless Card Replacement, Wireless Card: 8 단계, 이미지 2/3 Dell Inspiron i3558-5500BLK Wireless Card Replacement, Wireless Card: 8 단계, 이미지 3/3
    • Identify the Wireless Card as shown in the image.
    • Remove the power couplings by gently pulling them away from the assembly.
  9. Dell Inspiron i3558-5500BLK Wireless Card Replacement: 9 단계, 이미지 1/2 Dell Inspiron i3558-5500BLK Wireless Card Replacement: 9 단계, 이미지 2/2
    • Remove the 1 mm Phillips screw shown in the image.
  10. Dell Inspiron i3558-5500BLK Wireless Card Replacement: 10 단계, 이미지 1/1
    • Gently pry the wireless card upward from the screw-side and pull outward toward the edge of the laptop to remove.
결론
Nathan Ybanez
회원 가입일: 09/27/17
622 평판
안내서 6개 작성하였습니다
Cal Poly, Team S9-G5, Banghart Fall 2017 Cal Poly, Team S9-G5, Banghart Fall 2017 회원
CPSU-BANGHART-F17S9G5
4 회원들
안내서 13개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 2
7일 전: 7
30일 전: 17
전체 시간: 567
