이 안내서에는 최근 변경 사항이 더 있습니다. 최신 비검증 버전으로 전환하십시오.
소개
Replacing the display is difficult because there are delicate cables that need to be manipulated.
필요한 것
1 단계 Battery
주의: 1-3 단계들은 진행 중으로 표시된 안내서에서 제공되었습니다.
Flip your laptop over to view the bottom and locate the two locks.
Flip laptop right side up and open
Insert flat side of spudger gently along inside of screen and screen surround.
Work your way around the screen carefully releasing the screen surround from the lid.
다른 6명이 해당 안내서를 완성하였습니다.
댓글 4개
i cant figure out how to take off the cable to the display help
in step 4
jhgfds
This should be listed as "easy", and time taken around 10-15 minutes.
Agreed should be labeled easier. 10-15 minutes
